Calc. Christoffel Symbols of Hiscock Coordinates
The discussion focuses on the calculation of the Christoffel symbol ##\Gamma^\tau_{\tau\tau}## in the context of Hiscock coordinates, specifically addressing the metric components ##g_{\tau\tau}=v^2(1-f)^2-1## and ##g_{\tau r}=0##. Participants confirm that since ##g_{\tau\tau}## lacks explicit dependence on ##\tau##, the Christoffel symbol is indeed zero. The conversation references the paper available at https://arxiv.org/abs/gr-qc/9707024, which provides context for the metric used. The importance of precise calculations over assumptions is emphasized throughout the discussion.
  • Understanding of differential geometry and Christoffel symbols
  • Familiarity with Hiscock coordinates and their application in general relativity
  • Knowledge of metric tensors and their properties
  • Proficiency in mathematical tools such as Maple for symbolic computation
  • Study the derivation of Christoffel symbols in various coordinate systems
  • Explore the implications of static metrics in general relativity
  • Learn how to use Maple for calculating derivatives of metric tensors
  • Review the paper referenced in the discussion for deeper insights into Hiscock coordinates
This discussion is beneficial for physicists, mathematicians, and students specializing in general relativity, particularly those interested in the application of Christoffel symbols in curved spacetime metrics.
Onyx
TL;DR
Calculating the christoffel symbols of Hiscock coordinates.
The Hiscock coordinates read:
$$d\tau=(1+\frac{v^2(1-f)}{1-v^2(1-f)^2})dt-\frac{v(1-f)}{1-v^2(1-f)^2}dx$$
##dr=dx-vdt##
Where ##f## is a function of ##r##. Now, in terms of calculating the christoffel symbol ##\Gamma^\tau_{\tau\tau}## of the new metric, where ##g_{\tau\tau}=v^2(1-f)^2-1## and ##g_{\tau r}=0##, can I safely assume that ##\Gamma^\tau_{\tau\tau}=0##, since ##\frac{\partial g_{\tau\tau}}{\partial \tau}=\frac{\partial g_{\tau\tau}}{\partial r}\frac{\partial r}{\partial \tau}## (in the Jacobi matrix ##\frac{\partial r}{\partial \tau}=0)##?
What "new metric"? ##\tau## isn't a coordinate, it's proper time.
Not in this case, apparently. The new coordinates appear to be ##\tau,r##. This appears to be in reference to https://arxiv.org/abs/gr-qc/9707024.
PeterDonis said:
Where in this paper does the metric shown in the OP appear?
There isn't a complete metric in the OP, but the stated ##g_{\tau\tau}## and ##g_{\tau r}## match equation 12 given equation 10 for a definition of ##A(r)##.
I apoligize, I should have adopted ##dT## instead to be more clear.
Would it be possible to do it with something like Maple?
I'm struggling slightly to determine the definition of ##\tau## here. The definition you quote, given in the paper I found, is for ##d\tau##. By the chain rule that's ##\frac{\partial\tau}{\partial t}dt+\frac{\partial\tau}{\partial r}dr##, but I can't make sense of the coefficients in your definition in those terms. Am I missing something here?
This might help:
##d\tau=dt-\frac{v(1-f)}{1-v^2(1-f)^2}dr=dt-\frac{v(1-f)}{1-v^2(1-f)^2}(dx-vdt)=(1+\frac{v^2(1-f)}{1-v^2(1-f)^2})dt-\frac{v(1-f)}{1-v^2(1-f)^2}dx##
Onyx said:
This might help:
##d\tau=dt-\frac{v(1-f)}{1-v^2(1-f)^2}dr=dt-\frac{v(1-f)}{1-v^2(1-f)^2}(dx-vdt)##
My instinct is that, since it says that the metric is "manifestly static", ##\Gamma^{\tau}_{\tau\tau}## is indeed zero.
Don't guess, calculate. Generally you know that$$\Gamma^a_{bc}=\frac 12g^{ai}\left(\partial_b g_{ic}+\partial_c g_{bi}-\partial_i g_{bc}\right)$$so in this case$$\Gamma^\tau_{\tau\tau}=\frac 12g^{\tau i}\left(\partial_\tau g_{i\tau}+\partial_\tau g_{\tau i}-\partial_ig_{\tau\tau}\right)$$I think that the metric is diagonal, so the only non-zero ##g^{\tau i}## is the ##i=\tau## one. But since ##g_{\tau\tau}## has no explicit dependence on ##\tau## then the Christoffel symbol is indeed zero.
I was pretty sure of it was zero. Thank you. One last thing:
For the new metric, is ##n_a=(\sqrt{A},0)##?
  • · Replies 19 ·
