Circle tangential velocity approaching c
The discussion revolves around the effects of relativistic speeds on the tangential velocity of a rotating system, specifically using the analogy of a merry-go-round and later transitioning to the context of neutron stars. Participants explore concepts such as angular velocity, radius, and the implications of relativistic effects on measurements of distance and separation between points on a rotating body.
  • Some participants question whether the apparent closeness of points on a rotating merry-go-round is due to a reduction in angular velocity or radius.
  • Others argue that as the tangential velocity approaches the speed of light, the material of the rotating system would not remain rigid and would inevitably deform, complicating the analysis.
  • A participant introduces a scenario with beetles on a spinning disc to illustrate differences in measurement based on the frame of reference.
  • There is discussion about how measurements of distance between points on a rotating system may differ depending on the observer's frame of reference, including considerations of Doppler effects.
  • Some participants express skepticism about the premise that points on a rotating disc would appear closer together, suggesting that distances would remain the same in certain frames of reference.
  • A later reply shifts the focus to neutron stars, questioning whether angle contraction or radius contraction occurs when measuring distances at relativistic speeds.
  • Participants note the importance of defining the frame of reference when discussing measurements on rotating bodies, especially in the context of relativistic effects.
Participants express multiple competing views regarding the effects of relativistic speeds on measurements of distance and separation in rotating systems. There is no consensus on the implications of these effects, and the discussion remains unresolved.
Limitations include assumptions about the rigidity of rotating bodies, the nature of measurements in different frames of reference, and the complexities introduced by relativistic speeds. The discussion also highlights the challenges in applying classical mechanics to relativistic scenarios.
Osvaldo
When a merry go rounds tangential velocity approach c, and horses look closer than when at rest, what is reduced, angular velocity or radius?
The merry go round breaks, the angular momentum remains constant as the radius increases while the pieces fly apart.
This kind of question is tricky - it depends a lot on exactly what you mean.
Imagine you have a spinning disc and two beetles, one on the disc and one on the (non-rotating) floor. If you have both beetles walk the circumference of the disc then the one on the disc will take more steps to do it. If the beetles walk a radius they will agree on the distance.
However, if you start with a non-rotating disc and spin it up, you will find that both the disc's radius and circumference change compared to when it was stationary. As Dale says, this will eventually lead to the disintegration of the disc as you increase the spin rate. Infinitely strong infinitely rigid materials aren't consistent with relativity.
Note that the distance between the horses on your merry go round also depends what you mean. If there are N horses evenly spaced around the merry go round then this is true whether the thing is spinning or not, so their angular separation is not changed. What this means in terms of the measured distance depends on which frame is doing the measuring and what we are comparing to.
Obviously am not proposing this thread to discuss the resistance of the material spinning at higher speed. My point is if I am stationary and I measure that 2 points in the mass-less rotating circle get closer is it because angle I measure shrinks or because the radius of the sniping circle, measured from my stationary position is shorter?
Massless doesn't work - that would move at the speed of light in a straight line.
I don't think any points are likely to get closer to each other. It's a bit difficult to answer specifically because it's not entirely clear what you are comparing. My guess is that you are assuming that the disc doesn't expand significantly even when rotating at relativistic speeds, and you are comparing measurements (made in the non-rotating floor frame) of the disc when not rotating to measurements when it is rotating. Under that model the distances between horses don't change - how could they? The circumference doesn't change and the number of horses doesn't change.
If you make measurements on the disc, you'll find that the horses have moved apart. Strain gauges in the floor will show that the floor is stretched, however, which one can interpret as length contraction.
It doesn't work that way. The disk cannot possibly remain rigid. It must inevitably deform. As it does so the geometry of the disk changes, and the question can only be answered by analyzing the specific material involved and the resulting stresses and strains, which become infinite as the tangential velocities approach c.
OK so far
You just lost me here. My best guess is that you are trying to imagine a rigid rotating disk, though you haven't specified such a thing. As other posters have pointed out, a realistic rotating disk would break apart under the strain at tangential velocities of a few km/sec. So you are imagining somethign other than a realistic disk - but it's not clear what. A rigid rotating disk is my best guess.
If that's what you're imagining, we can go into more details on the notion of rigidity in special relativity, but I'm not sure that that's actually your question at this point.
pervect said:
OK so far
Are you acknowledging the question, or agreeing the premise that the horses will look closer together when the merry go round is moving? Because I don't think I agree with the premise under any interpretation of "look". As measured from the ground frame I think they'll be at least the same distance apart, and literally looked at from the ground frame they'll be uneven distances apart due to Doppler. Or am I missing something?
pervect said:
OK so far
I am not convinced even about that. I doubt that there is any material that would produce that result.
The idea is that the horses are arranged on the moving platform so that an observer positioned on the rim and using the momentary tangent inertial rest frame will measure their separation as "normal" and so that an observer positioned nearby on he ground will measure their separation as "closer".
Is this what you intend?
Osvaldo said:
When a merry go round's tangential velocity approach c, and horses look closer than when at rest...
If you want to know what the horses look like then you will need to account for light travel times from the different points on the merry-go-round. But if you want to know what is happening that's an easier question, and speeds close to c are not needed to conduct the experiment.
Seems to be the merry go round was not a good example. Forget about it and the horses. Let us think what happens at he periphery of a neutron star with 2 marks at the Equator of the star and separated 1 km. In response to Dale, there are about 100 Million Neutron stars in the Milky Way that spin at high rate. One of them PSR J1748-2446ad spin at 716 RPS or 24 % c at the perihery (radius 16 km) and as far as I know has not yet disintegrated as Dale thinks might happen.
Then if a stationary observer were able to measure the distance between the spots while rotating at 0.24c, beside measuring the length contraction, my question is is there an angle contraction or neutron star radius contraction?
These spots are separated by 1 km in what frame?
Edit: In my limited understanding, it is important to realize that the "rest frame" of the neutron star is an accelerating frame in which it is not possible to use the Einstein synchronization convention in a self-consistent manner. Accordingly, a naive expectation that the coordinate system corresponding to the rest frame will match the coordinate system corresponding to a tangent inertial frame may not be well founded.
There is no angle contraction. There is no radius contraction.
Neutron stars are problematic because they have very strong gravity and special relativity does not apply. Your merry-go-round, albeit made of a ridiculously strong material, is a better example.
If you use single nails to attach short rulers to the edge of the merry-go-round you will find the rulers to be length contracted with respect to rulers at rest. Thus, an observer on the merry-go-round would measure the circumference to be greater than ##2\pi r## (because they're using a curved coordinate system, not because spacetime is curved). Using this measurement method they will measure the distance between two horses to be greater than an observer at rest beside the merry-go-round. Note that this also applies to the distance between atoms and scales like the Lorentz ##\gamma##, which is one explanation for why the merry-go-round must disintegrate before the rim reaches lightspeed.
As @jbriggs444 noted, the merry-go-round is rotating so a frame attached to it is non-inertial. Many of the usual rules for inertial frames do not apply.
This leads to a larger question of; does Einstein's equations provide for rotational accelerations in General Relativity?
I'm not sure what you mean. This problem (excluding the neutron star) is entirely in flat spacetime, so would be classified as a special relativity problem. No GR is needed. You can handle rotating objects fine in SR.
If you mean, does the EFE predict that, for example, the material in a rotating neutron star will have nonzero proper acceleration, of course it does.
What I'm saying is that rotations introduce a radial acceleration; since acceleration is the domain of general relativity, has this acceleration been addressed by the equations?
If you mean coordinate acceleration, that depends on your choice of coordinates.
If you mean proper acceleration, that depends on the spacetime geometry; you can have spacetime geometries in which matter is rotating with zero proper acceleration.
No, it isn't. You can handle accelerations (either kind) in flat spacetime just fine using SR.
In any solution of the EFE which is not flat spacetime, the solution tells you the acceleration of a piece of matter in any state of motion you like.
As Peter says, all scenarios in flat spacetime are in the domain of special relativity, accelerating or not. A lot of SR is taught using exclusively inertial reference frames, but there's no obligation to restrict yourself that way. If you choose a more general approach, however, you need to be aware that simple rules relating inertial frames don't work.
The OP is using a rotating frame, which is fine, but I suspect he has imported a few intuitions from inertial frames without examining them. I might be wrong.
The Lorentz factor at 0.24 c is about 1.03, which is hardly what I had in mind by a “tangential velocity approaching c”.
In any case, to answer the question you would still need to consider the material properties of the neutron star. The point I have been making is that you cannot spin up something without distorting it. You will not simply have length contraction, but you will have an unavoidable stretching of the material. A spinning neutron star will be stretched compared to a non spinning one.
This is a fundamental difference between linear motion and rotational motion. For linear motion you can start from rest, and accelerate rigidly, meaning that strain gauges attached to the object will detect no strain. For rotational motion that is not possible. You cannot start from rest and undergo angular acceleration without having some strain somewhere. So what happens to the disk depends on the material properties of the disk
As others stated, acceleration can be treated just fine in SR, but if we want to pursue the neutron star idea, that would be GR.
Say forget about gravity of neutron star which might affect metric of nearby space and set a ring at rest in IFR almost touching periphery of neutron star. The ring would have number of 2*3.14*16km/1km marks. In the rotating neutron star frame of reference the marks are equidistant but more than 1km. When periphery speed is reaching c, the distance between marks goes to infinity. It is interpreted that pi, i.e. ratio of periphery to diameter, reaches infinity in geometry of the rotating reference frame. If you define angle be length of part of periphery divided by radius as we do for radian angle, angle between the marks increases. But of course sum of all the angles coming back to the origin is more than 2pi or 360 degree and the sum reaches infinity angle as periphery speed goes to c.
(We can set the same number of equidistant marks on the periphery with more than 1 km distance between in the rotating frame of reference. We need more number of marks for 1km distant set in the rotating frame of reference.)
No it isn’t. ##\pi## is a defined constant and it is always about 3.14 regardless of whether your geometry is curved or flat. The ratio of the circumference to the diameter is equal to ##\pi## for flat Euclidean geometry. For other geometries the ratio changes, but it is not ##\pi##
PeterDonis said:
You can handle accelerations in flat spacetime just fine using SR.
I must admit, I'm confused - I thought that special relativity dealt exclusively with inertial reference frames, and that's why it's deemed "special"? The Equivalence Principle finds that acceleration due to gravity is equivalent to acceleration due to motion, doesn't it? So then the "warping" of spacetime by massive objects should also occur due to accelerations, which means that the formerly flat spacetime is no longer flat.
I know the Equivalence Principle holds true for linear accelerations, but I wasn't sure about accelerations that aren't along the path of motion. I thought by extension they might. I also thought that they'd be described by the off-diagonal components of the Riemann tensor. Is that correct? Could you specify which components that would be?
Then you thought incorrectly. SR deals with flat spacetime. It can use any coordinates/reference frames you like as long as spacetime is flat.
No.
Incorrect.
The EP doesn't say what you think it says. See above.
No.
You seem to have some basic misunderstandings about the EP and about the motion of objects vs. the geometry of spacetime. I'm not sure where you are getting these misunderstandings from so I'm not sure how to help you clear them up. What sources have you learned all this from?
No - see, for example, the twin paradox, a classic of special relativity in which one of the twins accelerates. Special relativity deals with flat spacetime only, which is the special case referred to. It is perfectly possible to do everything in SR with only inertial frames (this does not preclude objects following non-inertial paths), and it was originally formulated that way, but you don't have to. Frames are a human invention - they don't change physics, just our description of it.
What's acceleration due to motion and how is it different to acceleration due to gravity?
There are a lot of formulations of the equivalence principle. One way is to say that being at rest on the surface of a planet is locally indistinguishable from accelerating in a rocket in flat spacetime. But this doesn't mean that gravity and acceleration are the same thing. The key point is that free-falling in a gravitational field isn't accelerating (in the sense of proper acceleration), while being at rest on the surface of a planet is. And in either case, it's the upwards force on the soles of your feet that is causing you personally to accelerate, not gravity.
This does not follow. Non-inertial frames correspond to choosing non-Euclidean slices of flat spacetime and calling them "all of space at an instant", while inertial frames correspond to using Euclidean slices, but the spacetime is flat in either case. It's like choosing to imagine slicing a block of wood (spacetime) into a stack of bowls (non-inertial frames) or a stack of plates (inertial frames). It's the same block of wood, and we're not actually slicing anything - it's just how we choose to think of dividing the block. Nothing is warped.
I can accelerate in a car hard enough to make objects roll around (in my frame). If spacetime were actually warped by me choosing to accelerate, things outside the car would be dragged around by the acceleration, too.
"Path of motion" implies a choice of frame. I can always choose a (possibly non-inertial) frame in which I am always at rest. How would you distinguish between a "linear acceleration" and an "acceleration that isn't along the path of motion" in that frame?
No. The Riemann tensor describes the curvature of spacetime, and there is no such curvature in flat spacetime. In non-flat spacetime the components will depend on your choice of coordinates, but that isn't affected by whether you are undergoing proper acceleration or not.
The postulates of special relativity do specifically reference inertial frames only. However:
1) you can analyze accelerated motion from an inertial frame. There is nothing that requires you to use a non inertial frame simply because some object is accelerating.
2) once you have physics figured out in an inertial frame then it is just a coordinate transform to get a non inertial frame. The math to change coordinates can be used in any physical theory, it isn’t owned by GR.
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 25 ·
