Circuits / Switches / Currents -TRUE FALSE QUESTIONS (Pic included)
The discussion revolves around true/false questions related to circuits, switches, and currents. Participants are exploring concepts of current flow, resistance changes, and power dissipation in electrical circuits.
  • Participants express uncertainty about their reasoning and seek clarification on the relationships between current, resistance, and power in circuits. Some attempt to articulate their thought processes regarding the true/false statements, while others question the validity of their assumptions.
There is an ongoing exchange of ideas, with some participants providing insights into the implications of closing and opening switches on circuit behavior. Guidance is offered regarding the need to consider equivalent resistance and current changes, although no consensus has been reached on the true/false questions.
Participants note the absence of reference materials and express a desire for explanations rather than direct answers. There is a recognition of the complexity of the concepts involved, particularly regarding power conservation and current flow in different circuit configurations.
niravana21
Circuits / Switches / Currents --TRUE FALSE QUESTIONS (Pic included)
I really have no idea, on going about solving this as I don't have my book with me and the homework is due in a few hours. I'm sure if brief explanations are provided with your're reasoning, I will be able to understand the concept.
I realize this is not the way of the physics forum, but I really am desperate right now.
Hope you guys understand. Thanks in advance.
A current will develop in the circuit when the switch is closed. After the switch is opened, the same current is within the circuit, however, the total resistance of the circuit has changed.
When you calculate the total initial resistance, is it larger than the resistance if you were to assume the middle branch is an open circuit?
After the switch is opened, a different current will flow, because the resistance has changed.
so if I'm understanding correctly, which I'm not too sure, would it go like this?
8.True
9.False
10.False
11. True
12. True
again, it would be helpful if you can tell me why I'm incorrect rather than provide the right answer. Thanks members!
If you would like someone to tell you why you are incorrect, you should at least explain why you think you are correct. :smile:
fair enough :) I don't even know if some of my reasonings are valid haha
8. The total power that is dissipated should be conserved so True
9. (not sure at all, just guessed)
10. Voltage stays the same though out the circuit so False
11. True because closing the switch causes current to flow though and increases resistance?
12. true because uhh it sounds true :) (not sure either way)
Sorry, this is not so. Energy may be conserved, power is another animal. The resistive load on the voltage supply changes, therefore the current changes. What is the equivalent resistance before the switch is opened? After it is opened? Assume the battery is 1.5V. What is the current (provided by the battery) before and after switch is opened? Use P=VI, P=VI, P=V2/R or P=I2R to compare power dissipated in each circuit.
After the switch is opened R2 is just dangling out there--how can current go through it?
When you figure out what the currents are (before/after switch opened) you will be able to answer this.
When you figure out the equivalent resistance of the circuits (before/after switch opened) you will be able to answer this.
When you figure out the current of circuits (before/after switch opened) you will be able to answer this.
10K
