Circuits with parallel resistors
The discussion focuses on calculating voltage and current in circuits with parallel resistors. In the first scenario, a circuit with a 10V battery and resistors R1=10ohm, R2=40ohm, and R3=50ohm confirms that the voltage across each resistor is 10V. In the second scenario, with resistors R1=10ohm, R2=20ohm, and R3=500ohm, the current through R2 is given as 100mA, leading to a calculated current of 200mA through R1, based on the voltage being the same across parallel resistors.
  • Understanding of Ohm's Law
  • Knowledge of parallel resistor circuits
  • Ability to perform basic electrical calculations
  • Familiarity with voltage-current-resistance (V-I-R) relationships
  • Study the principles of parallel circuits in electrical engineering
  • Learn how to calculate total resistance in parallel resistor configurations
  • Explore advanced circuit analysis techniques using Kirchhoff's laws
  • Investigate the impact of varying resistor values on current distribution
Students studying electrical engineering, hobbyists building circuits, and anyone interested in understanding the behavior of parallel resistor configurations.
chiurox
1) A circuit contains a 10V battery and three resistors in parallel. The resistors have values R1=10ohm, R2=40ohm, R3=50ohm. What is the voltage across each resistor?
2)This time, the 3 resistors in parallel have values R1=10ohm, R2=20ohm, R3=500ohm. The current flowing through R2=100mA. What is the current flowing through R1?
1) 10 V across each, because the voltage is the same across parallel resistors right?
2) I made a V-I-R chart. Since R2 has a current of 100mA and its resistance is 20ohm, then the voltage is 2.0V. Since the resistors are in parallel, the voltage is the same for R1.
So 2volts=I(10ohm)
I=200 mA is this correct?
Hi chiurox,
That looks correct to me.
yeah that's absolutely right
Oh... ok, I was a bit insecure. thanks
