Circular motion-centripetal acceleration
The discussion focuses on the relationship between linear velocity and angular displacement in circular motion, specifically addressing the formula delta(v) = v * delta(T). Participants clarify that while velocity changes direction in circular motion, its magnitude remains constant. The correct relationship is established as v = r * (dθ/dt), where r is the radius and θ is the angle. The confusion arises when delta(T) does not approach zero, leading to questions about the validity of the original formula in such cases.
  • Understanding of circular motion principles
  • Familiarity with angular displacement and its relationship to linear velocity
  • Knowledge of calculus concepts such as limits and derivatives
  • Basic proficiency in LaTeX for mathematical expressions
  • Study the derivation of centripetal acceleration formulas
  • Learn about the relationship between angular velocity and linear velocity in circular motion
  • Explore the concept of limits in calculus, particularly in relation to delta notation
  • Practice writing mathematical expressions in LaTeX for clarity in communication
Students of physics, educators teaching circular motion concepts, and anyone interested in the mathematical foundations of motion dynamics.
allok
hi
This latex code is giving me some problems. I write one thing, it displays something completely different
In circular motion velocity only changes direction but not size
change of velocity - \Delta v
Change of angle - \Delta T
Velocity - V
Centripetal acceleration - a
delta(V) = V * delta(T)
When delta(T) approaches its limit (goes to zero), change of velocity has same direction as acceleration vector?
We compute the magnitude of velocity change with :
Delta(v) = v * Delta(T)
I see this being true when change of angle approaches its limit ( goes to zero ), since then length of circular arc ( with radius begin velocity vector ) equals \Delta v. But that is not true if delta(T) is not approaching limit. So how can we use formula
delta(v) = V * delta(T)
in cases were delta(T) is not approaching zero, since I assume length of circle arc is quite different than delta(T) if delta(T) doesn't go to zero?
cheers
I think your original assumption may be incorrect. If you want to relate the linear velocity of the object on the circle circumference with the change in angle, it would be:
s = r\theta
\frac{ds}{dt} = r\frac{d\theta}{dt}
v = r\frac{d\theta}{dt}
where s is the circle arclength, r is the circle radius, and theta is the angle. The \frac{d\theta}{dt} would be equal to your \Delta T.
s = r\theta
I don't get it. First of all, v = r\frac{d\theta}{dt} is not same formula as delta(v)=v*delta(theta)
I still don't understand why delta(v) = v * delta(theta) would give us correct result when delta(theta) is anything but d\theta ?
  • · Replies 16 ·
11K
