Circular Motion Power: Why Isn't Work Done Equal to Zero?
The problem involves a particle of mass m moving in a circular path with a varying centripetal acceleration described by the equation a = k^2rt^2. The original poster questions why the work done, and consequently the power, is not zero despite the circular motion, suggesting that the resultant force is centripetal.
  • Participants explore the relationship between centripetal and tangential acceleration, questioning the role of tangential forces in doing work. Some participants attempt to derive power using different expressions for velocity and acceleration, while others express confusion about the definitions and components of velocity in circular motion.
The discussion is active, with multiple participants sharing their attempts and reasoning. Some have provided calculations that lead to different expressions for power, while others are seeking clarification on the assumptions regarding radial and tangential components of motion. There is no explicit consensus on the correct interpretation of the problem, but various lines of reasoning are being explored.
Participants are grappling with the implications of non-uniform circular motion and the definitions of centripetal and tangential acceleration. There is an ongoing examination of the assumptions regarding the nature of forces acting on the particle and how they relate to work done in circular motion.
hqjb
1. Homework Statement [/b]
A particle of mass m is moving in a circular path of constant radius r such
that its centripetal acceleration a varies with time t as [itex]a = k^2rt^2[/itex], where k is a
constant. Show that the power delivered to the particle by the forces acting on
it is [itex]mk^4r^2t^5/3[/itex]
Why isn't work done, hence power = 0 since it's moving in a circle and resultant force is centripetal?
Edit : Assuming there's a tangential component,
I take
[itex]a_c = k^2rt^2 = v_{tan}^2/r[/itex]
[itex]v_{tan} = √k^2r^2t^2 = krt[/itex]
[itex]a_{tan} = dv/dt = kr[/itex]
[itex]P = Fv = ma_{tan}v_{tan} = krt * kr * m ≠ mk^4r^2t^5/3[/itex]
I have got the answer you have mentioned but i am not sure what could be the reason that my answer is correct. I am sitting on my computer desk and following your thread but no one is yet replying, so i think i will post my solution and see if i could receive any feedback. I know its your thread hqjb, i hope you don't mind. :smile:
I integrated the expression for centripetal acceleration with respect to time and found [itex]v=\frac{k^2rt^3}{3}[/itex], (now i don't know which velocity is this. :confused:)
P=Fv
P=macv
[itex]P=m*k^2rt^2*\frac{k^2rt^3}{3}[/itex]
[itex]P=\frac{mk^4r^2t^5}{3}[/itex]
But still i don't have any reasoning to why is this correct?
a=k2rt2
v=k2rt3/3
E=1/2mv2=1/2m(k2rt3/3)2
P=dE/dt=(6/18)m(k4r2t5)
azizlwl said:
a=k2rt2
v=k2rt3/3
I get both of your workings, but I'm not sure why both of you used the radial component of velocity? (integrating centripetal acc = centripetal vel. right?)
Shouldn't only tangential component count in doing work?
I'm looking for the instantaneous velocity from instantaneous acceleration,irrespective of direction.
Energy is scalar.
I think that:
v[itex]^{2}[/itex]=v[itex]^{2}_{c}[/itex]+[itex]^{2}_{t}[/itex]
But v[itex]_{t}[/itex]=krt
And v[itex]_{c}[/itex]=[itex]\frac{k^{2}.r.t^{3}}{3}[/itex]
W=1/2.m.[itex]v^{2}[/itex]
P=dW/dt=...
takudo_1912 said:
I think that:
P=dW/dt=...
I get my original answer + everyone else's answer in this case :
[itex]k^2r^2tm + (k^4r^2t^5m)/3[/itex]
I think this was the correct answer :-s
Okay after thinking about it again, I think by definition circular motion means there is no "radial velocity". My bad for that mistake. But can anyone tell me what you get when you integrate radial acceleration? What about the v^2/r formula then(My notes says that it works for non-uniform circular motion)?
hqjb said:
I take
Your result looks fine. The centripetal acceleration is v2/r, even in case of non-uniform circular motion. There is no work done by the centripetal force if the particle moves along a circle. But there should be some tangential force to ensure increase of speed. The tangential force multiplied by the velocity (which is tangential of course) gives the power.
ehild
My understanding is when a body moves at
a=Ct2 where C=k2r
The velocity will be
v=Ct3/3
KE=1/2mv2
The particle moves along a circle with constant radius r
The velocity is tangent to the path.
The tangent of the circle is perpendicular to its radius : there is no "radial velocity".
There is radial acceleration: it is called "centripetal acceleration". There can be also tangential acceleration.
The centripetal force does not do any work.
The integral of the centripetal acceleration is neither velocity nor speed.
Think of the uniform circular motion. The centripetal acceleration is constant. Does the speed increase linearly with time?
ehild
ehild,
I don't think so. Let ω be constant and vector R = cosωt*i + sinωt*j. Then velocity vector V = dR/dt = -ω*sinωt*i + ω*cosωt*j , where V and R are at right angles to each other. So the acceleration vector is A = dV/dt = -ω^2(cosω*t*i + sinωt*j) = -ω^2*R, which is a vector in the opposite direction of R and whose magnitude is |V|^2/|R|. This derivation requires that ω be constant (uniform). Besides, the problem statement says that the centripetal acceleration is k^2*r*t^2.
Ratch
@ehild: Can i get some feedback on my solution? That would be very helpful. The solution is posted on page 1, post #2. :smile:
Pranav, think of the uniform circular motion. The centripetal acceleration is constant. Do you get anything reasonable if you integrate it with respect time? Is it the velocity or speed or anything? Is the speed of the uniform circular motion a linear function of time instead of being constant?
Read my post #13.
ehild
Ratch said:
The same thing as the diagram your link shows. Specifically, A = the vector sum of Ac and At.
Ratch
We totally agree then. The acceleration is the vector sum of Ac and At. Ac is the centripetal acceleration. Its magnitude is v2/r.
ehild
ehild
The speed is constant in uniform circular motion. The centripetal acceleration is constant in uniform circular motion but here the centripetal acceleration is varying with time.
I really have no idea what we get if we integrate the centripetal acceleration.
Hello hqjb and others,
I think the solution pasted in the attempt is correct.Circular motion uniform or non uniform “indeed requires the centripetal acceleration to be equal to(V^2/R)”.Let us prove it through calculus and polars.(2Dimensional avoiding the usage of axis of rotation)
We know that vector r of any point on the circle with O as origin at an elevation from say the horizontal (the diagram can be drawn easily) and with unit vectors as i and j is given as
R=R(cos(θ)i+sin(θ)j)
We define two other unit vectors e(r) and e(t) ,with the first pointing away from the center towards the radius and the second in the direction of the advancing tangent.
e( r )= cos(θ )i+sin(θ )j
e( t )= -sin(θ )i+cos(θ )j
e’( r )= e(t)*θ’(Differentiation w.r.t any variable)
Similarly
e’( t)=-e( r )* θ’
As such r=r*e( r ) ...$
V=rω*e(t)+r’e(r) ………………$$
/* Unless radius is changing w.r.t time velocity is always tangential as r’=0 */so
V=rω*e(t) ………………………$$$
(ω is angular velocity)
So that
a=-r(ω^2)e(r) +rαe(t) ………………$$$$ (radius taken constant once again)(alternatively use complex numbers for the same result)
In short only given that radius is constant the centripetal acceleration is ((v^2)/r) no matter what (we used v=rω in the radial portion of the last equation which arrives from our velocity vector expression)For other curvilinear trajectories the centripetal acceleration is defined by the general term “normal component of acceleration”The same equation works with only the r in the denominator being radius of curvature of the curve at that point .
So
(1) Integrating centripetal acceleration in any case of circular motion is not an act that brings forth any velocity.
(2) One need not worry about radial component of velocity here as it reduces to zero given the fact that radius is constant.
(3) Something is wrong with the question, it yields fine with the acceleration being defined plainly but is incorrect as regards circular motion and centripetal acceleration.
Apologies in advance for straying the discussion off topic if I did so.Correct me if I am wrong.
Regards
Yukoel
Nice post, Yukoel!:smile:
ehild
You integrated the centripetal acceleration to get the velocity thinking (I guess) that "velocity is integral of acceleration". You could do the same with constant centripetal acceleration could you not? And do you get anything that has sense?
See an example: a ball moves along a horizontal circle with radius R=1 with 2 m/s speed. So the centripetal acceleration is 4 m/s2. Integrate with respect to time: it is ∫adt=4t+const. What kind of speed is it? It is not the speed of the ball, as it is 2 m/s. It is not "radial velocity" as the radius is constant. Is it anything?
You have integrated the centripetal acceleration, so you need to know the reason why you did it. :biggrin:
You got the integral of the centripetal acceleration. It is not related to the velocity.
ehild
ehild
Thanks ehild :smile:
regards
Yukoel
Thanks for the explanation ehild! :smile:
Integrating centripetal acceleration really doesn't make any sense.
ehild
For finding out the answer as posted by OP, i tried integrating centripetal acceleration and by luck, i was able to get that answer. So the claimed answer is wrong (i guess)?.
I guess it is wrong. And I also guess they followed the same logic, that "velocity is integral of acceleration". It is true for the vectors and for the Descartes components, but not for the centripetal acceleration.
Well, getting the same answer as in the book is not always a "luck":biggrin:
ehild
Shouldn't the answer be Power=m*k^2*r^2*t?
ehild said:
...Descartes components...
ehild
Never heard of it, any link would help. :smile:
It is. That is the solution obtained and showed by the OP.
ehild
The goal of the problem was incorrect then, as stated in the original post?
So is the power given by dE/dt or by Fv, because the value of these two seem to differ (dE/dt=k^2r^2t, but Fv is the value in the original post).
  • · Replies 28 ·
  • · Replies 20 ·
