Is Angular Momentum Conserved During the Changing of the String Length?
The discussion centers on the conservation of angular momentum when the length of a string attached to a mass is shortened during motion. The object, with a mass of 500 g and an initial velocity of π m/s, moves in a circular orbit of radius R = 50 cm. When the string length is halved to r = R/2, the period of motion is calculated using the formula T = (2πR) / v, yielding a period of 0.5 seconds. However, the correct understanding is that angular momentum remains conserved despite the change in string length, which affects the period but not the speed of the mass.
  • Understanding of angular momentum and its conservation principles
  • Familiarity with circular motion equations
  • Knowledge of basic physics concepts such as mass, velocity, and period
  • Ability to manipulate algebraic equations for physical calculations
  • Study the principles of angular momentum conservation in various systems
  • Explore the effects of changing radius on circular motion dynamics
  • Learn about the relationship between linear velocity and angular velocity
  • Investigate the implications of conservation laws in different physical scenarios
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators looking for examples of angular momentum conservation in practical applications.
AlexanderIV
An object with mass m is attached to a string with initial length R, and moves on a frictionless table in a circular orbit with center C as shown in the figure. The string is also attached to the center, but its length is adjustable during the motion. The object initially moves with velocity v and angular velocity ω.
Given: m = 500 g, v = π m/s, R = 50 cm
If the length of the string is shortened from R to r = R/2 while the mass is moving, what will be the new period in SI units?
T = (2πR) / v
T = (2πR) / v = (2π0.5) / π = 1
=> T = (2πR/2) / v = 0.5 s
But apparently 0.5 is not the correct answer and I do not understand why.
Does the speed change when the string is shortened?
No, it doesn't.
AlexanderIV said:
No, it doesn't.
Can you think of any physical quantity that remains conserved during the changing of the length of the string? (Maybe it's something you have recently covered in your course.)
  • · Replies 71 ·
  • · Replies 17 ·
