Circulation of a flow field around circle (x-1)^2+(y-6)^2=4
The discussion centers on calculating the circulation of a flow field around the circle defined by the equation (x-1)2+(y-6)2=4. The velocity components of the flow field are given as u=3x+y and v=2x-3y. Through parametrization of the circle and integration, the circulation is determined to be 4π. Key insights include the importance of correctly applying the dot product and recognizing the radius of the circle as 2, not 4.
  • Understanding of vector calculus, specifically circulation and line integrals.
  • Familiarity with parametrization of curves in the xy-plane.
  • Knowledge of dot products in vector algebra.
  • Ability to perform integration over trigonometric functions.
  • Study the concept of circulation in fluid dynamics and its mathematical formulation.
  • Learn about parametrization techniques for different geometric shapes.
  • Explore vector calculus, focusing on dot products and their applications.
  • Practice integrating trigonometric functions in the context of line integrals.
Students and professionals in mathematics, physics, and engineering, particularly those focusing on fluid dynamics and vector calculus.
MichielM
A flow field on the xy-plane has the velocity components
<br /> u=3x+y <br />
<br /> v=2x-3y<br />
Show that the circulation around the circle (x-1)^2+(y-6)^2=4 equals 4\pi
The circulation \Gamma around a closed contour is:
\Gamma=\int_C\vec{u}\cdot d\vec{s}
Because the contour of investigation is a circle, a parametrisation of the form x=1+4\cos\theta, y=6+4\sin\theta should help.
The circulation then can be calculated as:
<br /> \Gamma=\int_0^{2\pi} \vec{u} \sqrt{\left(\frac{\partial x}{\partial \theta}{\right)^2+\left(\frac{\partial y}{\partial \theta}{\right)^2} d\theta<br />
Calculating the root yields 2 so:
<br /> \Gamma=\int_0^{2\pi} 2 \vec{u} d\theta<br />
To get 4\pi out of this, \vec{u} should 1, but this is the point where I don't know how to show/calculate that. The integration of the vector is the point where I get stuck. Any help is welcome!
Careful, the radius of the circle (x-1)^2+(y-6)^2=4 is 2[, not 4.
\sqrt{\left(\frac{\partial x}{\partial \theta}\right)^2+\left(\frac{\partial y}{\partial \theta}\right)^2} d\theta only gives the magnitude of the vector d\textbf{s}.
d\textbf{s}=dx\textbf{i}+dy\textbf{j}=\left(\frac{dx}{d\theta}\right)d\theta\textbf{i}+\left(\frac{dy}{d\theta}\right)d\theta\textbf{j}
(Since x and y depend only on \theta for this curve)
Oops, little to quick in my steps. So instead of 4 i take 2 in those equations.
I think I got it now:
<br /> d\textbf{s}=dx\textbf{i}+dy\textbf{j}=\left(\frac{ dx}{d\theta}\right)d\theta\textbf{i}+\left(\frac{d y}{d\theta}\right)d\theta\textbf{j}=-2\sin \theta d\theta\textbf{i}+2\cos \theta d\theta\textbf{j}<br />
Also performing the transformation for u yields:
<br /> \vec{u}=(3x+y)\vec{i}+(2x-3y)\vec{j}=(9+6\cos\theta+2\sin\theta)\vec{i}+(-16+4\cos\theta-6\sin\theta)\vec{j}<br />
Plugging everything into the integral and taking boundaries 'full-circle' I get:
<br /> \Gamma=\int_0^{2\pi}-2\sin(\theta)(9+6\cos\theta+2\sin\theta)d\theta\vec{i}+2\cos(\theta)(-16+4\cos\theta-6\sin\theta)d\theta\vec{j}<br />
Taking the integrals there are only 2 terms which don't completely cancel, the terms coming from the integration of \sin^2(\theta) and \cos^2(\theta) which add up to \Gamma=-4\pi \vec{i}+8\pi \vec{j}. Adding up this yields 4\pi but how come I can just add those two component up? Because I integrated both parts to the same parameter?
The integrand is a dot product. If you compute the dot product of \mathbf{u}\cdot \mathbf{v} you should get a scalar, not a vector.
(u_1 \vec{\mathbf{i}} + u_2 \vec{\mathbf{j}}) \cdot (v_1 \vec{\mathbf{i}} + v_2 \vec{\mathbf{j}}) = u_1 v_1 + u_2 v_2
Everything else you did is fine. You just have extra \vec{\mathbf{i}}'s and \vec{\mathbf{j}} where there should be none.
ah I see, thanks! My vector algebra has become a bit rusty in the last years.
  • · Replies 19 ·
