Clarification about Kirchhoff's law of thermal radiation
The discussion clarifies Kirchhoff's law of thermal radiation, which states that at thermal equilibrium, absorptivity (αλ) equals emissivity (ελ). The terms absorptivity and emissivity are intrinsic properties, while absorption (A) and emission (E) are extrinsic. The confusion arises from mixing intrinsic/extrinsic with intensive/extensive properties. Intrinsic properties, such as emissivity, do not change with the size of the object, while extensive properties, like mass, do.
  • Understanding of Kirchhoff's law of thermal radiation
  • Familiarity with intrinsic and extrinsic properties
  • Knowledge of intensive and extensive properties
  • Basic concepts of thermal equilibrium
  • Research the definitions and differences between intrinsic and extrinsic properties
  • Study intensive vs. extensive properties in thermodynamics
  • Explore applications of Kirchhoff's law in thermal radiation analysis
  • Learn about thermal equilibrium and its implications in physics
Students and professionals in physics, particularly those studying thermodynamics, as well as anyone seeking to clarify concepts related to thermal radiation and material properties.
carter7gindenv
Hello, I'd like some clarification with the exact wording of Kirchhoff's law of thermal radiation.
The law states that at thermal equilibrium αλλ.
However sometimes I read that absorptivity= emissivity and sometimes I read that rate of A. = rate of E.
Which one is correct? I'm not sure but I get an itch in the back of my head that it means the same thing.
Thanks for the help!
Science news on Phys.org
Basically you are correct, but you are using four terms, not two: absorptivity, emissivity, absorption (A), emission (E). Absoptivity and emissivity are intrinsic quantities. The other two are extrinsic.
That was what I feared. I feel like online documentation often confuses those terms. And I believe it is also the source of my confusion in my other thread here.
I will try to find more information about those 4 terms thank you very much!
Do you know the difference between an intrinsic and extrinsic quantity? If I have some object, like a can of soda, it has some mass and temperature. If I grab a second can of soda, I now have twice as much mass, but not twice as temperature. The temperature doesn't change with the amount of the substance, so we call this an intrinsic quantity. Mass is an extrinsic quantity.
This is something that has always been a bit badly explained to me but you broke it down very nicely thank you!
You are confounding intrinsic/extrinsic with intensive/extensive.
Properties that change with the size of the system are extensive; the that don't are intensive.
Intrinsic properties are those that belong to the object itself. For example, emissivity is intrinsic because it is a property of the object itself. It doesn't change with the size of the object, so it is also intensive, but it doesn't change with its temperature either, i.e., it doesn't depend on external factors.
Yes. Yes, I did. Thanks for the correction!
