Classical Mechanics - Drag Force
The discussion revolves around solving a physics problem involving a block sliding on a surface with a drag force proportional to the velocity raised to the power of 3/2. The user derives the velocity function through integration but expresses uncertainty about the position integral. A correction is noted regarding the drag force equation, clarifying that it is indeed F = -cv^(3/2). Participants suggest using a substitution method to simplify the integral for position, indicating familiarity with the necessary calculus techniques. The conversation highlights the challenges of integrating complex functions in classical mechanics problems.
zeromaxxx
Suppose a block sliding on a slippery horizontal surface experiences a drag force F=-cv3/2 where c is a positive constant. At time t=0, the block is at position x=0 with initial positive velocity. Find the velocity and position as a function of time. Derive an expression for the limiting distance the block travels, or show that there is no limit.
F=-cv3/2
For velocity:
I took the integral of the drag force
mdv = -cv3/2 dt
int [dv/v3/2]= -c/m * int[dt]
-2/v1/2 + 2/v01/2 = -c/m * t
Isolating for v:
v= [v01/2/ 1+ (cv01/2t/2m)]2
Can someone kindly check the arithmetic if I got it right.
As for position, I have trouble dealing with the integral of the velocity function. If someone can help me regarding this, it would be greatly appreciated.
Int [dv/v2/3] is not v1/2 but v1/3. See the error?
Yes, sorry there's a typo in the original question I put up, the drag force is F = -cv3/2 and not 2/3. Sorry for this, I hope you can go through it again. Thanks!
Okay. After you put v = dx/dt, the integral looks like Int [dx] = Int [dt/(a + b*t)2] where a and b are some trivial constants, right? That t integral is easy to do, you know how?
I am sleepy (read sloppy) right now, so I'd rather not fix those constants for you.
Hmm, it made more sense the way you put it though I still cannot determine the integral of t.
A substitution a + b*t = w (some random variable) brings it in the form Int [dw/w2] with some constants I have suppressed. Does it look familiar now?
  • · Replies 27 ·
