Classifying ODE's: What Determines Linearity and Order?
  • Context: Graduate
  • Thread starter Thread starter Lengalicious
    Classification
3 replies · 3K views
Lengalicious
When classifying an ODE do I just say whether its linear / non-linear and what order it is?
EDIT: Example: x2x'' + e-xx = t3 where x is function of t.
is this 2nd order, non linear and heterogeneous?
Also, would dx/dt = logte-x be homogeneous because both terms contain the dependent variable 't'?
There are some more classifications for (second order) odes, mostly based on the fact that the ode is solvable (or not) when it is of a certain class. I like the choice of the Maple software, which is pretty classic. The online description of odeadvisor giving you a classification is here:
http://www.maplesoft.com/support/help/Maple/view.aspx?path=DEtools/odeadvisor
Your first order ode is homogeneous, because it does not have a term that only depends on t. dx/dt=a(t)*x+b(t) is not homogeneous, but dx/dt = a(t)*x is. Your example is also separable, which means it can be solved using separation of variables.
so if dx/dt = logte-1, would that now mean that this was no longer homogeneous? Thanks for the help by the way.
Your equation is not homogeneous because of the t cubed term.
