Close tube with string oscillation
7 replies · 3K views
IIK*JII
In attached figure, a closed tube is placed near a string that is fixed at one end and has a weight attached to its other end. When bridges A and B are positioned at the points shown,plucking the string between A and B causes the tube to resonate at its fundamental frequency. Points a-e divide the length between A and B into 6 equal segments
Next, A is fixed in place, and B is gradually moved toward A while the closed tube is shifted so that it stays at the center of A and B. During this process, the string is repeatedly plucked between A and B. When B is at a certain point, the tube resonates at the next overtone above the fundamental frequency. Which of a-e represents that point? Here, the string's oscillation is only fundamental oscillation
Close tube; L= (2n-1)[itex]\frac{λ}{4}[/itex] ; n= 1,2,3...
String fixed end; λ=2L/n
In 2nd period the tube oscillate at f3
L = [itex]\frac{3}{4}[/itex]λ
∴λtube=[itex]\frac{4}{3}[/itex]L ...(1)
String ; λstring=2L (oscillate at f1) ...(2)
Divide (1)/(2) I got [itex]\frac{λ<sub>tube</sub>}{λ<sub>string</sub>}[/itex] = 2/3
From that I guess the point is a point number 2 from first 3 points, so I don't know that I should choose point b or d as my answer. Also, I don't know that my method is correct or not...
Help is appreciated :)
Thanks
The question is not how much you have to reduce the entire wavelength on the string but how far to move the blocks ...
Thank you very much Simon Bridge :)
Did you mean the block should move up?? and I should find height of the block when it moves up??
What I am saying is that you have calculated a ratio in whole wavelengths, but the distance you need to find (in order to know where to put the block) is that for a half-wavelength. You need to check to see what sort of difference, if any, that makes.
Presumably, the ratio of the fundamental to the first harmonic in the tube is the ratio of string wavelengths needed right? You already know the half-wavelength needed to make the string oscillate at the tube's fundamental frequency and you are keeping the tension, and so the wave-speed, fixed.
I hope I'm not confusing you - it is really hard to write about without actually telling you the answer. Basically the numbers you got look good - I'm trying to get you to work out if the numbers you got are the ones you need ... what you really need is a relationship along the lines of [itex]x_2=ax_1[/itex] where x1 is the distance |AB| that got you the fundamental in the tube and x2 is the distance between the blocks that gets you the second fundamental and a is the ratio between them.[1]
What you have is that [itex]\lambda_{tube} = \frac{2}{3}\lambda_{string}[/itex]
[1] actually you can finesse it by looking for the relation [itex]x_2=\frac{n}{6}x_1[/itex] since n will tell you which of the lettered points to move the block to :)
Thank you Simon Bridge,,
your explanation is good help me imagine what this problem want
I think, for example, x2 from your meaning is length of string that I can find from wavelength right??
Bear in mind that I think you are very close and I have not actually done the problem myself. It's intreguing - I'll have to set it up as an experiment sometime.
