Lost Kinetic Energy in Inelastic Collision of Putty and Pivoting Rod
  • Thread starter Thread starter kingsmaug
    Rod
The discussion focuses on the inelastic collision between a piece of putty (mass m = 0.75 kg, velocity v = 2.5 m/s) and a pivoting rod (mass M = 2 kg, length L = 0.9 m). The initial kinetic energy (KE) of the putty is calculated to be 2.34 J, while the final KE after the collision is determined to be 1.24 J. The fraction of kinetic energy lost during the collision is correctly calculated as approximately 0.47. The error in the initial calculation stemmed from using an incorrect velocity value of 2 m/s instead of the correct 2.5 m/s.
  • Understanding of inelastic collisions and conservation of momentum
  • Familiarity with rotational dynamics and moment of inertia calculations
  • Knowledge of kinetic energy formulas: KE = 1/2mv^2 and KE = 1/2Iw^2
  • Ability to apply angular velocity concepts in collision scenarios
  • Study the principles of inelastic collisions in detail
  • Learn about the calculation of moment of inertia for various shapes
  • Explore the relationship between linear and angular momentum
  • Investigate the effects of different collision points on the outcome of inelastic collisions
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking for practical examples of inelastic collisions and energy conservation principles.
kingsmaug
A piece of putty of mass m = 0.75 kg and velocity v = 2.5 m/s moves on a horizontal frictionless surface. It collides with and sticks to a rod of mass M = 2 kg and length L = 0.9 m which pivots about a fixed vertical axis at the opposite end of the rod as shown. What fraction of the initial kinetic energy of the putty is lost in this collision?
KE = 1/2mv^2
KE = 1/2Iw^2
L=mvr
L=Iw
I=mL^2/3
I=mr^2
r=L (I'm using the pivot as the point of origin)
Based on the wording, it's an inelastic collision, and the putty sticks to the rod.
So, momentum is conserved:
mvL = (mL^2/3+mL^2)w
Using numbers, I found that w = 1.176 rad/s
The initial KE is 1/2mv^2= 2.34
The final KE is 1/2Iw^2= 0.79
KElost/KEi=(KEi-KEf)/KEi = 0.66
but the answer is wrong.
Did the problem statement give any information regarding where the putty sticks to the rod? I see you assumed that it stuck to the end of the rod. If you guessed "wrong", that could be your source of error. Under this assumption I am also calculating a different value for the angular velocity post-collision.
If the mass is striking the end of the rod, that's too low. Are you confusing yourself by using 'm' for both masses in the equation?
I don't believe I'm using the wrong ones.
So working it over using the proper masses:
KE = 1/2mv^2
KE = 1/2Iw^2
L=mvr
L=Iw
I=ML^2/3
I=mr^2
mvL=(ML^2/3+mL^2)w
w=mvL/(ML^2/3+mL^2) = 1.47059 rad/sec (I don't understand why it isn't the same, but whatever...)
KEi = 1/2mv^2 = 2.34375 J
KEf = 1/2(ML^2/3+mL^2)w^2 = 1.24081 J
(KEi-KEf)/KEi = 0.470588 Which is correct.
And looking through my calculator's log, I found exactly where I went wrong the first time. I accidentally used 2 as the velocity instead of 2.5. :| The stupid feelings.
