Closed implies exact (differential 1-forms on R^2)
The discussion centers on the relationship between closed and exact differential forms on ##R^2##, exploring the definitions and implications of these concepts within the context of differential geometry. Participants examine proofs, theorems, and various approaches to understanding how closed forms relate to exact forms, including the use of line integrals and Green's theorem.
  • Some participants define a closed differential form on ##R^2## as one where ##\frac{\partial F}{\partial y} = \frac{\partial G}{\partial x##, while an exact form is one that can be expressed as the differential of a scalar function.
  • One participant questions where the assumption of closedness is utilized in the proof that closed implies exact, seeking clarification on the definitions involved.
  • Another participant references a theorem indicating that if a differential form is exact, it must be closed, and discusses the implications of the operator properties related to exterior differentiation.
  • Several participants discuss the application of Green's theorem, noting that path integrals being independent of the path implies the form is exact, and that closed forms yield zero integrals over closed paths in convex domains.
  • There is mention of the famous angle form being closed and locally exact in certain domains, highlighting the importance of the domain's properties in defining antiderivatives.
  • One participant suggests that in contractible regions, the homotopy can be used to define the antiderivative function, referencing the Poincaré lemma.
  • Another participant expresses difficulty in understanding general proofs related to closed and exact forms, indicating a need for clearer motivation in the proofs.
Participants express various viewpoints on the relationship between closed and exact forms, with some agreeing on the implications of theorems while others seek clarification or express uncertainty about specific proofs and definitions. The discussion remains unresolved regarding the clarity of certain proofs and the application of concepts in different contexts.
Some participants note limitations in their understanding of the proofs related to the Poincaré lemma and the properties of differential forms, indicating that the discussion may benefit from further exploration of these concepts.
PhDeezNutz
TL;DR
As the title of the thread states. A set of notes https://www.math.purdue.edu/~arapura/preprints/diffforms.pdf#page4
From section 1.4 (pages 4-7)
Theorem 1.4.1 states that if a closed differential 1-form on ##R^2## must be exact (i.e. a total differential of scalar function ##f \left( x,y \right)##)
I don’t understand how the proof provided is valid
A differential form on ##R^2## has the following form
##df = Fdx + Gdy##
It is closed if ##\frac{\partial F}{\partial y} = \frac{\partial G}{\partial x}##
And like I said earlier, a form is exact if there exists scalar function ##f \left(x,y\right)## such that ##F = \frac{df}{dx}## and ##G = \frac{df}{dy}##
In order to prove closed ##\Rightarrow## exact the author does a line integral along two joined paths.
1. The path from ##(0,0)## to ##(x,0)## where ##x## changes and ##y## is constant
Unioned with
2. The from ##(x,0)## to ##(x,y)## where ##y## changes and ##x## is constant
They seem to integrate and then re-differentiate as follows
##df = F dx + G dy##
## \int \, df = \int F \,dx + \int G \,dy##
##f = \int_{0}^{x} F\left(t,0 \right) \,dt + \int_{0}^{y} G\left(x,t\right) \,dt##
If we take the partial ##x## and partial ##y## derivative using the fundamental theorem of calculus we very much get
##\frac{\partial f}{\partial x} = F \left(x,y\right)##
##\frac{\partial f}{\partial y} = G \left(x,y\right)##
This is the sketch of the “proof” but I don’t understand where the assumption of closedness was used. Or any related corollary.
Can someone please guide me? Did I get the definition of closed wrong?
Two pages earlier, on page three, we read ...
So we have just shown that if a differential is to be exact, then it had better be closed.
... which means that exactness implies closedness.
Theorem 1.4.1 gives conditions for which the converse is also true.
Exactness means that given a differential form ##\nu## we can find another one ##\omega## such that ##\nu=d\omega.##
As ##d^2=0, ## we get ##\operatorname{im}d\subseteq \operatorname{ker}d.##
Closedness means that ##d\nu =0## which is the case if ##\nu=d\omega ## due to ##d^2=0.##
I have tried to explain it in my own words in this post:
https://www.physicsforums.com/threads/why-the-terms-exterior-closed-exact.871875/#post-5474443.
See also the link there to MO
http://mathoverflow.net/questions/48491/why-are-differential-forms-called-closed-and-exact
When you take partial with respect to ##x##, you get
##f_x= F(x,0)+\int_0^yG_x(x,t)dt##
Then you use the closedness condition to rewrite it as
##f_x = F(x,0) + \int_0^yF_y(x,t)dt##
Which integrates to
##f_ x= F(x,0) + F(x,t) |_0^y = F(x,0) + F(x,y) -F(x,0) = F(x,y)##
Which integrates to
I see it now. Once the derivative is brought inside the integral it changes from the partial derivative of G wrt x to partial derivative of F wrt y. Then the fundamental theorem is invoked.
another similar approach is to use Green's theorem to conclude that the path integral is the same, no matter what path you integrate over. Then to compute the y derivative, you approach by a path from below, and to compute the x derivative you approach by a path from the side.
I.e. in general a form is exact if and only if path integrals are independent of path (by the argument above), if and only if the integral around any closed path is zero. And Green's theorem implies that path integrals of closed forms over a closed path are zero in any convex domain, such as the plane, since in such domains a closed path always bounds a portion of a surface (parametrized surface if necessary, or one can just restrict to polygonal paths).
These arguments show that a form is closed if and only if it is locally exact, i.e. exact in every open disc in the domain, (but the "antiderivative" may have to change as the disc changes). E.g. the famous angle form (-ydx + xdy)/(x^2+y^2), is closed and locally exact in the complement of the origin, since it equals "dtheta", but the precise values of the multi-valued angle function "theta" must be changed as its domain of definition changes. Here we see that the domain does not have to be strictly convex to define an antiderivative function, since here it suffices to remove any ray from the origin to infinity. The general condition is "in a simply connected domain" for the integral of a closed form to be independent of path. I.e. it suffices that any closed path in the domain can be deformed continuously to a point.
If the region where the form is defined is contractible, as in this case, don't you use the homotopy H taking it to a point to define the " antiderivative" form?
@WWGD: Since a contractible region its simply connected, you can define the antiderivative function f(p) as the path integral of the one-form along any path from a base point p0 to the point p. I will try to review what techniques are used specifically for contractible regions. I think you are right, but I have tended in the past to skip reading some of these proofs of the general "Poincare' lemma" in contractible regions, i.e. that any closed p-form of any degree is exact there.
................. later:
Ok, my eyes still glaze over when I try to read general proofs like the one in Spivak, Calculus on Manifolds, pages 94-95, (written there for "star shaped" regions, i.e. contractible along straight lines), but you are right. A contraction homotopy H of a region A to a point p0, gives a specific path contracting each point p to the base point p0, and the proof is essentially to integrate over that path.
My own footnotes in my copy say the proof is better motivated and clearer in Spivak's book Differential Geometry, chap. 7, pp.(7-29) through (7-37) of vol.1, 1970 edition, and also in Harley Flanders, Differential Forms.
After his proof in Diff Geom, Spivak remarks that the importance of the exterior differentiation operator d is highlighted by a theorem of Palais, that the only non - zero operators on forms (up to constant multiples), that commute with "pull back", are
1) the identity operator, from p-forms to p-forms,
2) exterior differentiation d, from p forms to (p+1) forms, and
3) integration, from n forms to (0-forms).
As a nice corollary, since d^2 also commutes with pullbacks, d^2 must be zero, without any tedious calculation. I.e. by this theorem there are no non - zero such operators from p forms to p+2 forms.
  • · Replies 36 ·
  • · Replies 0 ·
  • · Replies 0 ·
