Closure of Connected Space is Connected
  • Thread starter Thread starter Bashyboy
    closure Space
4 replies · 3K views
Bashyboy
If ##C## is a connected space in some topological space ##X##, then the closure ##\overline{C}## is connected.
Suppose that ##\overline{C} = A \cup B## is separation; hence, ##A## and ##B## are disjoint and do not share limit points, which means ##A \cap \overline{B}## and ##\overline{A} \cap B## are both empty. Since ##C## is connected and is contained in ##\overline{C} = A \cup B##, it must be contained in exactly one of the two partitions. WLOG, suppose that ##C \subseteq A##. Then ##C \subseteq A \subseteq \overline{C}## implies ##\overline{A} = \overline{C}##, and therefore ##\emptyset = \overline{A} \cap B = \overline{C} \cap B## implies ##B= \emptyset. Hence, ##\overline{C}## is connected.
How does this sound?
I think a little more is needed here. C is connected in the topology of X but to argue that that means it is in either A or B you need to first show that C is connected in the subspace topology of ##\bar C## (as it is in that topology that A and B are open, not necessarily the topology of X).
Okay. Here is an attempt a remedying the solution. First, let ##cl_X(S)## denote the closure of ##S## in ##X##'s topology, and likewise ##cl_{\overline{C}}(S)## denotes the closure of ##S## in ##\overline{C}##'s topology. By way of contradiction, suppose that ##C## is separated in ##\overline{C}##. Then there exist ##P, Q \subseteq \overline{C}## such that ##C = P \cup Q## and ##cl_{\overline{C}}(P) \cap Q## and ##P \cap cl_{\overline{C}}(Q)## are both empty. But since ##\overline{C}## is closed in ##X##, ##cl_{\overline{C}}(P) = cl_X(P)## and ##cl_{\overline{C}}((Q) = cl_X(Q)##, and therefore ##cl_X(P) \cap Q## and ##P \cap cl_X(Q)## are both empty. This means that ##C## is separated in ##X##, contradicting our hypothesis.
Sorry for the funky notation.
Your notation is fine. What you wrote is perfectly clear. Unfortunately, I don't find the above convincing. The 'Then there exist...' does not use the standard definition of a separation, as it does not say anything about open sets. Maybe you are using some theorem about a criterion that is equivalent to the definitional criterion for being a separation, but if so that theorem needs to be quoted.
I think the problem is actually easiest to do just using the basic definition of separation/connectedness, which is that C is connected in X iff for any open subsets A,B of X such that ##C=(A\cap C)\cup (B\cap C)## (which we note is equal to ##(A\cup B)\cap C## so that the condition may be restated as ##C\subseteq A\cup B##), the set ##(A\cap C)\cap(B\cap C)## must be non-empty (and we note that is equal to ##A\cap B\cap C##).
So to prove that ##\bar C## is connected in X given that C is, suppose that there are open subsets A,B of X such that ##\bar C\subseteq A\cup B##. Then it is fairly straightforward to use the above definition of connectedness of C in X to prove the connectedness of ##\bar C##.
Yeah...Sorry about that. Here is the theorem I am using:
If ##Y## is a subspace of ##X##, a separation of ##Y## is a pair of disjoint nonempty sets ##A## and ##B## whose union is ##Y,## neither of which contains a limit point of the other (i.e., ##\overline{A} \cap B## and ##A \cap \overline{B}## are both empty)
Of course, ##\overline{A}## denotes the closure of ##A## in ##X## which is ##cl_X(A)## using my notation.
