Coefficient of Friction and Energy
The problem involves a sled sliding on a frictionless surface that encounters a rough patch of ice, leading to a change in velocity. The goal is to determine the coefficient of friction between the sled and the rough ice, using principles of kinetic energy and forces.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of kinetic energy before and after the sled encounters friction, questioning the relevance of certain values used in their calculations. There is exploration of the work-energy theorem and its application to find the work done by friction.
Participants are actively engaging with each other's reasoning, correcting calculations, and exploring different interpretations of the forces acting on the sled. Some have provided guidance on how to approach the problem, while others are questioning the assumptions made regarding forces and acceleration.
There is a focus on understanding the relationship between work, force, and acceleration, with some participants expressing confusion about the application of these concepts in the context of the problem. The discussion reflects a mix of correct and incorrect assumptions that are being examined.
Blakeasd
A 30kg sled is sliding on a frictionless sheet of ice at a velocity of 4m/s. The sled encounters a rough patch of ice and begins to slow down. After traveling on the rough patch of ice for 3m, the sled's velocity is 2m/s. Determine the coefficient of friction between the rough ice and sled.
KE = (1/2)mv2
FF = uk * FN
W = f * d
v2 = vi2 + 2a(x - xi)
I begin by finding the Kinetic energy when the sled is on the frictionless sheet of ice:
KE = (1/2)mv2
KE = (1/2) * (30) * 42
KE = 240J
Then I find the Kinetic Energy when the sled is on the rough patch:
KE = (1/2)mv2
KE = (1/2) * (30) * 22
KE = 60J
I now note the amount of energy released due to friction:
240J - 60J = 180J
I continue to evaluate the force acting on the sled when on the rough patch:
W = fd
60J = f * 3m
f = 20N
Then I solve for acceleration in the rough patch:
4 = 0 + 2*a*3
a= (2/3)
Now I sum the forces:
20N - (uk * (30kg * 9.8)) = 30kg * (2/3)
uk = 0
This is obviously not correct as it states friction is present. I don't know where I'm making a mistake. Presumably my logic is incorrect, not the math itself. I think finding the kinetic energy for the frictionless surface was useless with the approach I'm taking.
Could anyone please help me understand what's incorrect?
Thanks.
Hi Blakeasd! :smile:
W = fd
60J = f * 3m
f = 20N
No, W = 180J. :wink:
(and what is the relevance of acceleration? :confused:)
Thank you for your response.
When I sum up the forces, I set them equal to ma. I need acceleration so I can solve for the coefficient of friction.
Can you please explain how you found work to be 180J .
Thanks!
The work energy theorem says that the change in mechanical energy equals the work done
That change is 180J :wink:
(and you can get µ from W = Fd and F = µmg)
Ok, I see why it is 180J, thanks! Here is my revamped work:
W = fd
180J = f * 3m
f = 60N
60N - (u * (30*9.8)) = (2/3) * 30
u = -.14
This is not a choice, though:
a.) 0.07
b.) 0.12
c.) 0.20
d.) 0.27
e.) 0.60
When I use W = Fd and F = umg , I get .204 (an answer choice).
So why doesn't this work when I sum forces? If I were to assume constant velocity, then summing forces would work, but how could I tell it is constant velocity? Why is it appropriate to assume this?
4 = 0 + 2*a*3
a= (2/3)
No, that should be
16 = 4 + 2*a*3
a= 2 :wink:
corrected for a, that's 60N - (µ * (30*9.8)) = 2 * 30
which is F - µmg = ma
that's wrong because you've used the same force twice
there is only one force (= ma), and it's either F or µmg :smile:
I don't understand how I'm using the same force twice. I take the force pushing the object forward and subtract the force of friction pushing in the other direction. When summing forces I thought it is necessary to set their sum equal to ma. Am I missing something fundamental?
Thanks!
there is no force pushing the sled!
if it wasn't for the rough patch, the sled would go on for ever at 4m/s
the only force is the friction! :smile:
Ah... so if I were to sum the forces:
0 - (u*30*9.8) = 60
u = .204
It works!
If you don't mind me asking another question, can you explain you reasoning for: v2 = vi2 + 2a(x - xi)
16 = 4 + 2*a*3
Why don't you use 2m/s for the final velocity?
Thanks!
Blakeasd said:
… can you explain you reasoning for: v2 = vi2 + 2a(x - xi)
16 = 4 + 2*a*3
ohhh, that should have been
4 = 16 + (-2)*a*3
a= -2 …​
the acceleration from the friction is actually -2 :wink:
