Calculating Impact Velocity Using Coefficient of Restitution
To calculate impact velocity, the height from which an object is dropped and the height it bounces back can be used to determine the coefficient of restitution (CoR). The discussion emphasizes that the mass of the ball is not necessary for calculating impact velocity, as the equations for constant acceleration can be applied directly. While some mechanical energy is lost during the bounce, the CoR is not required to find the final impact velocity. Instead, using the heights involved allows for a straightforward calculation of both impact and rebound velocities. Understanding these principles is crucial for accurately assessing the dynamics of bouncing objects.
bionut
Hi all, I know this may see basic but how would I go about calcualting Impact velovity?
The only information I have is:
Height dropped, height bounced and from here I can calculate the CofR...
But how would I go about finding impact velocity
Conservation of energy.
YEs, I thought of that... but don't know the mass of the ball?
bionut said:
Yes, I thought of that... but don't know the mass of the ball?
Use m for the mass of the ball.
Both KE & PE are proportional to the mass, m.
I don't get the question, i think it is wrong just because there is no need for the Coefficient of Restitution to find the impact (final ) velocity .
The Equations for constant acceleration , once applied would be used to find the Impact velocity AND the rebound velocity
Some mechanical energy is lost in the bounce. Thus there is a coefficient of restitution.
