Coefficients in the power series
esisk
Hi,
I am trying to prove something, but I need some kind of a result on the coefficients of a power series.
Suppose f(z) has a power series expansion about zero (converges). What can I say about the sum of the absolute values of the coefficients? Ideally I would like to show this sum is less than 1.
thank you
[tex] \frac{1}{1 - x} = \sum_{n=0}^{\infty} x^n for \ all \ | x | < 1[/tex]
If we denote a_n to be the coefficient of the nth term, then then a_n = 1 for all n, in which case,
[tex] \sum_{n = 1}^{\infty} 1 \rightarrow \infty[/tex]
Or in the case when it does converge, consider:
[tex] e^x = \sum_{n=0}^{\infty} \frac{x^n}{n!}[/tex]
Letting x = 1, we'd be summing the coefficients, i.e.
[tex] \sum_{n=0}^{\infty} \frac{1}{n!} = e[/tex]
It seems your hypothesis fails.
In light of L'Hospital's comment I need change my plan of of attack on the question. I think I need to state the question I was trying to prove:
If f(z) : D--->D where D is the open unit disk, and
the first (k-1) derivatives at zero vanish,
I would like to show that
If(z)I <= IzI^k Tha is abs{f(z)} \leq abs{z}^k
I believe one can (an the question is possibly intended to be solved this way) approach it using Schwarz, I was trying to do it by brute force whereby expanding the power series and saying
f(x)=z^k g(z) and somehow show that I g(z) I <= 1. I am failing as of now.
Any help? I thank you for your time
