Coefficients of a Taylor Series
The discussion focuses on finding the coefficients of the Taylor series for the function f(x) = ln(10 - x). The derivative f'(x) = 1/(10 - x) is expressed as a geometric series, leading to the series representation. The integration of the series is discussed, with the correct approach being to factor out 1/10^(n+1) and integrate, resulting in the first few terms of the series: x/10, x²/200, x³/3000, x⁴/40000, and x⁵/500000. The importance of correctly applying integration techniques is emphasized throughout the conversation.
  • Understanding of Taylor series and power series representation
  • Knowledge of differentiation and integration techniques
  • Familiarity with geometric series and their convergence
  • Basic algebraic manipulation skills
  • Study the derivation of Taylor series for various functions
  • Learn about geometric series and their applications in calculus
  • Practice integration techniques, particularly with power series
  • Explore the convergence criteria for power series
Students studying calculus, mathematicians interested in series expansions, and educators teaching power series concepts will benefit from this discussion.
lxman
The function f(x)=ln(10-x) is represented as a power series:
\sum^{\infty}_{n=0}a_{n}x^{n}
Find the first few coefficients in the power series. Hint: First find the power series for the derivative of .
Okay, start seems fairly straightforward:
f'(x)=\frac{1}{10-x}
I factor out \frac{1}{10} to arrive at:
f'(x)=\frac{1}{10}*\frac{1}{1-\frac{x}{10}}
I then arrive at the geometric series:
\sum^{\infty}_{n=0}\frac{1}{10}*\frac{x^{n}}{10^{n}}
Things begin to get a bit fuzzy for me from here. Next, I need to integrate WRT x to arrive at a solution for the original f(x). I believe this would result in:
\sum^{\infty}_{n=0}\frac{1}{10}*\frac{x^{2n}}{2(10^{n+1})}
Am I correct to this point, and where do I go from here?
Good so far, but
I'm quite lost at how you found this integral. The integral of
\sum_{n=0}^{+\infty}{a_nx^n}
is
C+\sum_{n=0}^{+\infty}{\frac{a_n}{n+1}x^{n+1}}
So I don't quite see how you got that 2n in the exponent...
Thank you for the reply.
I am sure your misgivings are justified. I am viewing this as an integration problem. Therefore I conclude that I need to obtain:
\int\frac{1}{10}*\frac{x^{n}}{10^{n}}dx
Using standard integration techniques I perform the following:
\frac{1}{10}\int\frac{x^{n}}{10^{n}}dx
=\frac{1}{10}\ \frac{x^{2n}}{2(10^{n+1})}
Have I erred at this step?
Okay, writing that out and looking back over it, I see an error.
x^{2}\ x^{n} should be x^{2+n}.
Correcting that mistake, I now arrive at:
\sum^{+\infty}_{n=0}\frac{1}{10}\ \frac{x^{2+n}}{2(10^{n+1})}
How about now?
No, that's also not good :frown: I'm confused at how you obtained that 2...
What is \int{x^ndx}??
this last step is incorrect. first, i would factor out the \frac{1}{10^{n}} so we get:
\frac{1}{10^{n+1}}\int{x^{n}}dx
which integrates to:
\frac{1}{10^{n+1}}\frac{x^{n+1}}{n+1}+C
OK, now that I see it, I understand. I was taking n to be a constant and performing:
\int\ x\ dx
which gives me:
\frac{x^{2}}{2}
and then trying to lump the n's back in. My mistake there.
So, taking:
\frac{1}{10^{n+1}}\ \frac{x^{n+1}}{n+1}+C
my first few terms would then be:
\frac{x}{10}+C
\frac{x^{2}}{200}+C
\frac{x^{3}}{3000}+C
\frac{x^{4}}{40000}+C
\frac{x^{5}}{500000}+C
seems correct. you don't need a +C for each term though, you can combine them all to one constant.
cheers
