Coin on Turntable: Find Max Distance w/o Slipping
  • Thread starter Thread starter julz3216
    Turntable
The problem involves determining the maximum distance a coin can be placed from the center of a rotating turntable without slipping, given the turntable's rotation speed and the coefficient of static friction between the coin and the surface.
  • Participants discuss the relationship between angular velocity and linear velocity, with some attempting to convert rotational speed into linear terms. There are questions about the correctness of the equations used and the calculations performed.
Some participants have provided calculations and attempted to clarify the relationship between angular and linear velocities. There is an ongoing exploration of the correct approach to the problem, with no explicit consensus reached on the final answer.
Participants are working within the constraints of the problem statement and are questioning the accuracy of their calculations and the equations applied. There is a focus on ensuring the correct conversion of units and understanding the underlying physics principles.
julz3216
A coin is placed on a turntable that is rotating at 45.0 rpm. If the coefficient of static friction between the coin and the turntable is 0.186, how far from the center of the turntable can the coin be placed without having it slip off?
mv^2/r <= usmg
us= coefficient of static friction
I tried using the equation and I converted 45 rpms to rad/sec and I got r=12.17 but this is wrong so I don't know what to do. Maybe I am using the wrong equation?
Can you show more details of your calculations? We can't see what you've done wrong if you don't show your work.
mv^2/r =usmg
v^2/r = usg
(4.71^2)/r <= .186g
22.184 = 1.8228r
r= 12.17
This seems logical to me but it says it is wrong.
Note: the 4.71 rad/s, is angular velocity. You need to convert that to m/s, which is linear velocity. Do you know the relationship between these two? It should be in your textbook.
I think v = omega*r
Where v is the velocity, omega is angular speed (rad/s), and r is the radius.
so v= 4.71r
then (4.71r)^2/r= 22.18r = 1.8228
so r= .082
which is right! thank you!
You're welcome. :smile:
  • · Replies 20 ·
