Collinear Vectors: Quick Questions Answered
  • Thread starter Thread starter Chris L
    Vectors
The discussion revolves around the concept of collinear vectors, specifically addressing the conditions under which two vectors are considered collinear and exploring a problem involving the determination of a scalar value that makes two given vectors collinear.
  • Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss whether two vectors are collinear if the angle between them is 180°. There is an exploration of methods to determine collinearity, including the use of the dot product and the implications of solving for a scalar multiple. Questions arise regarding the complexity of the algebra involved and whether simpler methods exist.
The discussion is active, with participants providing insights into the nature of collinearity and questioning the assumptions made about the relationship between vectors. Some participants express concerns about the validity of certain approaches and the implications of extraneous solutions in algebraic methods.
There is a mention of the potential confusion between the concepts of collinearity of vectors and the conditions for lines being parallel and sharing a point. This highlights the need for clarity in definitions and assumptions in the context of vector mathematics.
Chris L
Two quick questions:
1. Are two vectors considered collinear if the angle between them is 180°? (My guess would be yes, but it can't hurt to double check)
2. Let's say you're given a problem like this:
"given A = (1, 2, 3) and B = (x, 5, 6), find the value of x such that A and B are collinear"
The first method that comes to mind is to recognize that the cosine of the angle between the two has to be 1 (or -1 as well, depending on the answer to my first question), and from there using the definition of the dot product to conclude that A dot B = |A||B|. However, using this method, you have now turned what appears to be a reasonably straightforward problem into one that involves using the quadratic equation and generates an extraneous solution, requiring you to check both values to determine which one is actually valid.
Is there a simpler way to solve a problem like that, or is there no choice but to do all of that ugly algebra?
Yes.
The first method that comes to mind is to recognize that the cosine of the angle between the two has to be 1 (or -1 as well, depending on the answer to my first question), and from there using the definition of the dot product to conclude that A dot B = |A||B|. However, using this method, you have now turned what appears to be a reasonably straightforward problem into one that involves using the quadratic equation which generates an extraneous solution, requiring you to check both to find the one that is actually valid.
Vectors that are collinear are scalar multiples of each other. For this problem if u and v are collinear, then u = kv for some scalar k, and with u = <1, 2, 3> and v = <x, 5, 6>.
So for that particular problem, there doesn't happen to be a solution since 2 = 5k and 3 = 6k, and obviously there isn't a value for k that satisfies both of those. Thanks for your response
Not that I disagree, but does co-linearity necessarily follow? IIRC two lines are co-linear iff they are parellel and share a point.
The question was about vectors, which can be moved around so that they begin at an arbitrary point. If we're talking about direction vectors for two lines, it's possible for the lines to be parallel (with the vectors being scalar multiples of each other) so that the lines don't share a common point.
  • · Replies 20 ·
  • · Replies 21 ·
