Collision/conservation of linear momentum
The problem involves a collision between a 2.00 kg mass and a simple pendulum consisting of a 1.50 kg mass. The pendulum is initially at rest and is struck by the 2.00 kg mass, causing it to rise vertically. The scenario also includes the motion of the 2.00 kg mass as it travels along a frictionless surface and then encounters a 30-degree incline with kinetic friction. Participants are tasked with determining the initial velocity of the 2.00 kg mass before the collision.
  • Participants discuss the conservation of linear momentum and energy equations to analyze the collision and subsequent motion. There are attempts to calculate the final velocities of both masses post-collision and the effects of the incline on the 2.00 kg mass. Questions arise regarding the interpretation of initial and final velocities and the forces acting on the masses.
Some participants have provided calculations for the velocities involved, while others seek clarification on specific terms and values. There is an ongoing exploration of the relationships between the velocities before and after the collision, as well as the forces acting on the 2.00 kg mass as it moves up the incline. No consensus has been reached on the correctness of the calculations presented.
Participants note the importance of understanding the forces acting on the 2.00 kg mass on the incline and the initial conditions of the pendulum. The problem includes specific values such as gravitational acceleration and the coefficient of friction, which are relevant to the discussion but not fully resolved.
jnmoyer
A simple pendulum consists of a 1.50 kg mass connected to a cord without any mass or friction. Initially the pendulum is vertically positioned when a 2.00 kg mass collides with it, causing the pendulum to displace vertically upward 1.25 m. After the collision, the 2.00 kg mass travels along the frictionless horizontal surface, until it meets a 30 degree incline with a coefficient of kinetic friction of .400. If the mass travels a maximum distance of 1.125 m up the incline, determine the initial velocity that the 2.00 kg mass strikes the pendulum with.
I used:
Po=Pf Original Momentum = to Final Momentum
M1V1o+M2V2o=M1V1f+M2V2f Conservation of Linear Momentum
P=MV
Ei=Ui+Ki
Ef=Uf+Kf
U=MGh
Ki=1/2MVi^2
Kf=1/2MVf^2
(Uf-Ui)+(Kf-Ki)=-fd
MGYf+MGYo+1/2MVf^2-1/2MVo^2=The coefficient of friction times Nd
sin(theta)=Y/d
Sorry for the poor organization, All lower case letters are meant to be subscript except for the "h" in "U=MGh" and the "d" at the end of the last two equations.
I've been working on this for a few days, I think I may have come up with something. I believe the final velocity of the pendulum when it reaches 1.25m height is 4.95 m/s. Also, I'm having difficulty dealing with the 30 degree incline and how that affects the velocity of the 2.00kg mass. I got a velocity of 2.57 m/s when the mass reaches the base of the incline but am not sure where to go from there.
Edit: I think I may have gotten an answer. I used the conservation of linear momentum equation with the velocity of the pendulum and the velocity of the mass at the base of the incline. I got the initial velocity of the 2.00kg mass to be 6.28 m/s. If anyone can confirm this or tell me where I went wrong I would really appreciate it.
Your initial velocity ( not the final ) is correct. When the 2 kg mass in moving up the inclined plane, what is the total force acting on it so that it stops after moving certain distance?
By my initial velocity are you saying that the initial velocity that the 2.00kg mass strikes the pendulum with is correct? Or are you saying that the velocity when the mass approaches the ramp is correct? Is the final velocity of the pendulum at the top of its swing wrong? Sorry, just want to clarify exactly what you're saying.
I'm actually checking this forum for my fiancee while she is away from the house, so I'm not exactly sure how to do any of this until she gets back. She would like to know what information she would need to use to find the force acting on the 2kg mass on the inclined plane. In the problem you are also told g=9.80 m/s^2
It is non of these. It is the initial velocity of 1.5 kg.
I'm still not really sure what you mean. You said the initial velocity of 1.5kg. The initial velocity of the 1.5kg mass is 0. It is still on a pendulum and is struck by the 2kg mass. I need to find the initial velocity that the 2kg mass strikes the pendulum with.
After impact of 2 kg mass, what is the initial velocity of 1.5 kg of mass? That is what you have found. Now you have to find out what is the velocity of 2 kg mass when it starts climbing the inclined plane.
Ok, we've been working on this this whole time. We found the velocity of the 2kg weight after collision to be 4.32 m/s resulting in a final answer of the initial velocity of the 2kg weight being 8.0325 m/s. Is any or all of this right?
I was wondering if anyone ever figured this one out completely? I think that if you get the initial velocity of the 2.00kg mass at the base of the incline then that can be used as the final velocity after it strikes the 1.50 mass, and so can be used in this equation
MVinitial + mVinitial = MVfinal + mVfinal
Is this correct thinking?
16K
