Collision of Two Swinging Bars, Maximum Angle
tzonehunter
Diagram of two uniform bars pivoted at a common hinge: a thin bar labeled m, l on the left and a thicker bar labeled 2m, 2l on the right, with the lower bar dashed, and a note reading at position l below pivot, Ug = 0.
Two uniform bars have masses and lengths of [itex]m[/itex], [itex]l[/itex] and [itex]2m[/itex], [itex]2l[/itex], respectively. The bars are pivoted at the common frictionless hinge as shown. The bars are released from the horizontal position in such a way that they collide and stick together at the bottom position. After that, the bars swing upward together. Find the maximum angle θ the bars would make with the vertical after the collision.
I chose to solve this in 3 steps:
1) Use conservation of energy of C.O.M. of each bar to determine ω of each bar just prior to collision.
2) Use conservation of angular momentum to determine ω of the two bar system immediately after collision.
3) Use conservation of energy to determine final height of the C.O.M. of bar 2, and use that to find θ.
Step 1:
Bar 1:
[itex]U_{gi} + E_{ki} = U_{gf} + E_{kf}[/itex]
[itex]mgl + 0 = \frac {mgl}{2} + \frac {I_{pivot}ω_1^2}{2}[/itex]
[itex]I_{pivot} = \frac {m L^2}{3}[/itex]
[itex]m = m, L = l[/itex]
[itex]mgl = \frac {mgl}{2} + \frac {ml^2ω_1^2}{6}[/itex]
[itex]\frac {g}{2} = \frac {l}{6}ω_1^2[/itex]
[itex]ω_1 = \sqrt{\frac {3g}{l}}[/itex]
Bar 2:
[itex]2mgl + 0 = 0 + \frac {I_{pivot}ω_1^2}{2}[/itex]
[itex]I_{pivot} = \frac {8m l^2}{3}[/itex] [itex](m = 2m, L = 2l)[/itex]
[itex]2mgl = \frac {8ml^2ω_2^2}{6}[/itex]
[itex]2g = \frac {8l}{6}ω_2^2[/itex]
[itex]ω_2 = \sqrt{\frac {3g}{2l}} = \frac{1}{2}\sqrt{\frac {6g}{l}}[/itex]
Step 2: Apply conservation of angular momentum to determine the angular velocity of both bars immediately after collision.
[itex]L_{before} = L_{after}[/itex]
[itex]I_1ω_1 - I_2ω_2 = -(I_1 + I_2)ω_{both}[/itex]
[itex]\frac {ml^2}{3}\sqrt{\frac{3g}{l}} - \frac {8ml^2}{3}(\frac{1}{2}\sqrt{\frac{6g}{l}}) = -(\frac {ml^2}{3} + \frac {8ml^2}{3})ω_{both}[/itex]
[itex]\frac {1}{3}\sqrt{\frac{3g}{l}} - \frac {4}{3}\sqrt{\frac{6g}{l}} = -(\frac {1}{3} + \frac {8}{3})ω_{both}[/itex]
[itex]\frac {4\sqrt{6g} - \sqrt{3g}}{3\sqrt{l}} = 3ω_{both}[/itex][itex]ω_{both} = \frac {\sqrt{g}}{9\sqrt{l}}(4\sqrt{6} - \sqrt{3})[/itex]
Step 3: Apply conservation of energy to the swinging 2 bar system to determine [itex]h_2[/itex].
This picture shows the change in position of the center of mass of each bar from the collision to the top of the swing. I truncated the 2nd half of each bar to try to simplify the picture. I have drawn both bars separately.
Diagram of two bars swinging from pivots after a collision: a short bar of length l/2 on the left and a long bar of length l on the right, each at angle θ from vertical, with heights h1 and h2 marked.
Starting with the 2nd bar:
[itex]l cos θ = l - h_2[/itex]
[itex]h_2 = l - l cos θ[/itex]
Now the first bar:
[itex]\frac{l}{2} cos θ = \frac{l}{2} - h_1[/itex]
[itex]h_1 = \frac{l}{2} - \frac{l}{2} cos θ = \frac{1}{2}h_2[/itex]
Since the C.O.M. of the shorter bar starts at a position of [itex]\frac{l}{2}[/itex] above the reference point,
[itex]h_{1 final} = \frac{1}{2}h_2 + \frac{l}{2}[/itex]Now apply conservation of energy:
[itex]U_{gi} + E_{ki} = U_{gf} + 0[/itex]
[itex]mg(\frac{l}{2}) + 2mg(0) + \frac{1}{2}(I_{pivot1} + I_{pivot2})ω_{both}^2 = mgh_{1 final} + 2mgh_2[/itex]
[itex]mg(\frac{l}{2}) + \frac{1}{2}(\frac {ml^2}{3} + \frac {8ml^2}{3})ω_{both}^2 = mg(\frac{h_2}{2} + \frac{l}{2}) + 2mgh_2[/itex]
[itex]\frac{1}{2}(\frac {l^2}{3} + \frac {8l^2}{3})ω_{both}^2 = g\frac{h_2}{2} + 2gh_2[/itex]
[itex]3l^2ω_{both}^2 = gh_2 + 4gh_2[/itex] **Equation 1
NOTE: THIS IS WHERE I MADE THE ERROR! I DIDN'T FOIL CORRECTLY! MY 7th GRADE MATH TEACHER WOULD BE FURIOUS.
Take a detour to simplify [itex]ω_{both}^2[/itex]:
[itex]ω_{both}^2 = \frac {g}{81l}(16*6 - 2*4\sqrt{3*6} + 3)[/itex]
[itex]ω_{both}^2 = \frac {g}{81l}(99 - 8\sqrt{2*9})[/itex]
[itex]ω_{both}^2 = \frac {g}{81l}(99 - 24\sqrt{2})[/itex]
[itex]ω_{both}^2 = \frac {g}{27l}(33 - 8\sqrt{2})[/itex]Insert our expression for [itex]ω_{both}^2[/itex] into Equation 1 above:
[itex]3l^2(\frac {g}{27l}(33 - 8\sqrt{2})) = 5gh_2[/itex]
[itex]\frac {l}{9}(33 - 8\sqrt{2}) = 5h_2[/itex]
[itex]h_2 = \frac {l}{45}(33 - 8\sqrt{2})[/itex]
Insert our expression for [itex]h_2[/itex] into [itex]l cos θ = l - h_2[/itex] from the very top:
[itex]l cos θ = l - \frac {l}{45}(33 - 8\sqrt{2})[/itex]
[itex]cos θ = \frac {12 + 8\sqrt{2}}{45}[/itex]
θ = 58.8 degrees Note: This is the correct answer. I discovered my mistake above.
So, as noted, I found the mistake I made and did get the correct answer. This was an arduous problem.
