Moxin
- 24
- 0
Here's the Problem: A bullet of mass m=19.8 g is shot vertically upward into a block of wood of mass M=119 g that is initially at rest on a thin sheet of paper. The bullet passes through the block, which rises to a height of H=0.71m above its initial position before falling back down. The bullet continues upward to a maximum height of h=4.70m. Using energy conservation, you can express the velocities of the bullet and block immediately after the bullet exits the block in terms of the heights h and H. Use this to somehow determine the initial velocity of the bullet.
This is How I Tackled through the Guidance of BOTH My (HORRIBLE) Physics Book and My (EVEN WORSE) T.A.:
Using Conservation of Energy I came up with the Eq'n:
(1/2)(m+M)v^2= MgH + mgh
I solved for v and got 5.01
Apparently that's not the answer, so then I took a hint given in the book and Used Conservation of Momentum to get the equation:
mv(initial) = (M + m)v
I solved for v initial and got 35.1 m/s
But apparently, It's STILL Wrong.. I've tried slight variations of the above two equations, and yet, I still continue to get it wrong. I'm not sure what the problem is..Can anyone help?
