Collision with 3 particles and inelastic string
5 replies · 2K views
Perpendicular
The problem :
3 identical balls lie on a smooth horizontal surface, the 3rd ball moving with a velocity v while the other 2 are stationary and inter-connected via a taut inelastic string. Ball 3 strikes ball 2 normally making angle = 30 degrees with the string. Energy is conserved. We need to find post-impact velocities and impulsive tension.
My attempt :
By the usual principle that elastic collisions between identical bodies exchange velocities, ball 3 should become stationary while ball 2 acquires V and a part of it gets canceled by tension which then acts on ball 1 and the final result is such that both balls 1 and 2 move with equal final velocities.
However this doesn't match the options given. What exactly am I doing wrong ?
Do you have a sketch of the setup? Where is ball 1, relative to the collision of ball3/ball2?
Ball 1 and 2 could rotate around their common center of mass afterwards (together with a common movement), depending on the setup. In addition, ball 1 could be involved in the first collision, as the string is inelastic.
Crude ASCII art :
B1
B3->...B2
The angle B3B2B1 is 30 degrees, obviously. The string is represented by the "-"s.
Well in that case, B2 cannot move with the original velocity of B3 - it has to transmit a force to B1, therefore B2 will be slower.
You can set up an equation system with all conserved quantities as equations and solve that.
So conserving angular momentum, linear momentum, and energy should be enough, yeah ?
You need an additional equation to express that force in the string can act in the direction of the string only.
1 equation for angular momentum
2 equations for linear momentum
1 equation for energy
1 equation for the string
This leaves one degree of freedom, which corresponds to the impact point of B3. If they collide head-on, you can an additional equation for the direction of momentum transfer (here, it is identical with zero vertical velocity of B3 after the collision).
