Columb distance/charge balancing problem
  • Thread starter Thread starter Specialmias
2 replies · 5K views
Specialmias
A meter stick has two charges placed on it at the 0 mark is a charge of +1 coulomb. On the 100cm mark is a charge of +4 coulombs. Where should a proton be placed on the meter stick so that the net force due to both charges is 0.
Kc = Coulomb const.
Q= charge
a=unknown distance from +1 on proton
b= unknown distance from +4 on proton
X= proton on line
(Kc*Q1*Qn)/r^2= Force 1 on n
So far I've attempted to do the following:
+1_________________+4
The proton must fall in some region between the two.
If we take 50cm to be the origin of this system and 100 to be +50cm and -50 to be the negative maximum the system at 0 then the +1 charge acts on it towards the negative X direction. So it goes from this:
0________100cm
to
-50cm_______0_______50cm
-[(Kc*Qproton*Q+1)/a^2]+(Kc*Qproton*Q+4)/b^2 = 0
This however, gives me:
[b^2/a^2]=4/1
b/a=2/1
Which to me says that in order for this equation to be true then the distance to the proton on the +4 charge must be twice that of the distance from +1. However I can't seem to find any reasonable way to put this on the meter stick. The only possibility I can think of that would follow this is that the proton must be 30cm from the +1 charge and 60cm from the +4 charge but this still leaves 10cm that don't exist on the meter stick.
Have been working on this for a few hours now and am beginning to think maybe I'm thinking about this the wrong way. Any help is greatly appreciated.
Welcome to PF!
Specialmias said:
… in order for this equation to be true then the distance to the proton on the +4 charge must be twice that of the distance from +1. However I can't seem to find any reasonable way to put this on the meter stick. The only possibility I can think of that would follow this is that the proton must be 30cm from the +1 charge and 60cm from the +4 charge but this still leaves 10cm that don't exist on the meter stick.
Hi Specialmias! Welcome to PF! :smile:
Yes, you're right … the distance to the proton on the +4 charge must be twice that of the distance from +1.
Now calm down! …
just use algebra …
start by saying "if the distance from the 0 cm mark is x cm, then … " :wink:​
Oh wow. 3X completely whooshed by my head. You've saved my sanity, thank you.
