Combining Cos(t)'s from (sin2t + sin3t)/2*sint
  • Context: Undergrad
  • Thread starter Thread starter toneboy1
18 replies · 7K views
toneboy1
The question was given: x(t) = (sin2t + sin3t)/2*sint
determine the period. So I converted numerator and denominator into the exponential forms and ended up getting (after flipping, timesing and cancelling)
(exp(j3t)-exp(-j)-exp(j)+exp(-3j)+exp(j4)-exp(-2j)-exp(j2)+exp(-4j)) / 2
which in turn turns into
x(t) = cos(3t) - cos(t) - cos(2t) + cos(4t) if I'm not mistaken
so is there a way of simplifying this into maybe one Cos or something so I can find the period?
Or have I done this question the wrong way?Thanks heaps!
use sin(2t)=2sin(t)cos(t). then write sin(3t)=sin(2t+t) and expand it. next use
[itex]\cos(2t) = 2 \cos^{2}t - 1[/itex]. you then end up with
[tex]x(t) = \cos t + 2 \cos^{2}t - \frac{1}{2}[/tex]
samalkhaiat said:
...then write sin(3t)=sin(2t+t) and
That is very clever.
So I got to:
(2.sin(t).cos(t) + sin(2t).cos(t)+cos(2t).sin(2t)) / 2sin(t)
[2.sin(t).cos(t)+2sin(t).cos(t).cos(t)+(cos^2(t)-sin^2(t))*(2.sin(t).cos(t)) ]
/ 2sint
(then) although I have ended up with cost+cos^2 t + cos^3 t - sin^2(t).cost
Have I done something wrong or am I not finished simplifying it? (I can't think of what else to do).Thanks
Thanks heaps!
Once you have a sum of cosines, the period is the lowest common multiple of the periods of the terms.
So I got to:
Thanks
sin(t+2t) = sin(t)cos(2t)+sin(2t)cos(t)
What about if the Cosine is negative? Anyway so that would mean from the answer in my original post the period was 't'?
Thanks
Isn't that what I did?
Thanks
-cos(x)=cos(x+π)
That component will have a phase of π, in respect to the other components. Does not change the period, though.
nasu said:
-cos(x)=cos(x+π)
Ah, I see. So it was '1'. When I plotted the sum of: x(t) = cos(3t) - cos(t) - cos(2t) + cos(4t) in MATLAB it generated a period of 6.275 or something, how can this be?
Observe the picture attached
What would you expect? What is the period of cos(t)?
Please enlighten me, 360 deg?
In radians is 2π or about 6.28.
so from the result I got, how was 2π≈6.28?
I am not sure what are you asking. The value of 2π is not a consequence of your result but the other way around.
π or "PI" is 3.1415...
so 2π= 6.28...
Now the period of a function like sin(x) or cos (x) is 2π. This means that sin(x+2π) = sin(x).
In these expressions x is a non-dimensional variable.
You can also write sin(x+360) = sin(x) but then your x should be in hexadecimal degrees too.
Matlab uses radians, I suppose.
so 2π= 6.28...
AH! Because I was plotting it like it was in Time (seconds)
Playing Devil's advocate, would it be fair to make 't' as seconds and plot the thing and say it took 6.28 seconds for a period?
In physics we usually make the arguments of the functions non-dimensional.
A physical quantity periodic in time will be represented by something like
sin(2∏t/T) so t is in seconds and T is the "physical" period, in seconds.
This has the property
sin[2∏(t+T)/T)]=sin(2∏t/T) so the period is T.
what do you mean by 'non-dimensional' exactly?
Could I plead the case that since that T is 2π, it is 6.28 seconds?
How did the 'sin[2∏(t+T)/T)]' come about?
No, look again at your calculations. you put
[tex]\sin (2t) = \sin (2t) \cos (t) + \cos (2t) \sin (2t)[/tex]
which is wrong.
which is wrong.
You're right, thanks, would you be happy with:
(2.sin(t).cos(t) + sin(2t).cos(t)+cos(2t).sin(t)) / 2sin(t)
[2.sin(t).cos(t)+2sin(t).cos(t).cos(t)+(cos^2(t)-sin^2(t))*sin(t)) ]
/ 2sint
∴ 2cost + 2cos^2(t) +Cos^2(t)-(1-cos^2(t)) / 2
∴ 2Cos^2(t) + Cos(t) - 1/2
which is about as simple as you can get, with a period 2π?
Thanks
