Combining Parametric Equations
5 replies · 10K views
robbondo
Show that every point on the line v = (1,-1,2) + t(2,3,1) satisfies the equation
5x - 3y - z - 6 = 0
So what I did was solve the equation v by adding the x,z,and z components to get
x = 1 + 2t
y = -1 + 3t
z = 2 + t
So I'm thinking that if I can combine these into one equation that I would end up getting the answer. Problem is I can't figure out how to combine the three equations in an equation with all three variables. I keep getting the function in terms of two variables, or the wrong answer all together. One method I used was solving the z equation for t and then plugging it into the x equation and then the y equation. I tried setting they both equal to zero...
t = z -2
y = 3z-7 y - 3z + 7 = 0
x = 2z-3 x - 2z + 3 = 0
y - 3z + 7 = x -2z + 3
y - z - x + 4 = 0
Obviously this isn't the correct answer. What am I doin' wrong here?
Cool... that works. Why didn't my method work also? Is there more than one equation that can solve that parametric equation?
Stupid answer goes here.
Was my algebraic logic correct though? The answer I got was not off by a constant.
Never mind, I'm an idiot. A line doesn't determine a plane. Wow. Your work is fine, it's just you found a plane that the line is in that isn't the plane you started with.
