What is the Relationship Between Uncertainty in Diameter and Radius?
  • Thread starter Thread starter swain1
    Uncertainties
The uncertainty in radius is half of the uncertainty in diameter, as confirmed by the formula radius = diameter / 2. If the diameter's uncertainty is ±0.02 cm, the radius uncertainty is ±0.01 cm. When dealing with percent uncertainties, the percent uncertainty remains the same for both radius and diameter. To calculate the uncertainty in the volume of a sphere, the formula used is ΔV/V = 3 × Δr/r. This approach indicates that the volume's uncertainty will be larger due to the cubic relationship with radius.
swain1
If the uncertainty in a measurement of dameter is +-0.02cm is the uncertainty in radius the same or half of this value. The formula given in wikipedia implies that it would be half of the value.
Cheers
Cheers
Yes, it will be half of this value. If the uncertainty had been given in percent form, then the percent uncertainty on the radius and on the diameter would be the same.
you should had this formula in your relevant equations thingy:
radius = diameter /2
2 is a number, and has uncertainty of 0
so, use division rule
Ok thanks guys.
I now have to work out the uncertainty in the voume of a sphere using the radius I have. Any clues on how to get the uncertainty in this value? I would expect that it would be bigger but I can't really understand why?
I have this formula
deltav/v=3xdeltar/r
Is this correct?
  • · Replies 16 ·
  • · Replies 16 ·
