Comet Sublimation: Why Does Halley's Comet Still Exist?
  • Context: Undergrad
  • Thread starter Thread starter hexanol
    Comet Sublimation
The discussion centers on the sublimation of comets, particularly Halley's Comet, and explores why it continues to exist despite the apparent rapid sublimation of ice observed in a household freezer. Participants examine the effects of temperature, solar irradiance, and vapor pressure on sublimation rates in the context of comets' orbits and environments.
  • One participant notes that a significant tail forms from volatile components only when a comet is close to the Sun.
  • Another participant discusses the exponential dependence of vapor pressure on temperature, comparing conditions in a freezer to those in space, suggesting that lower temperatures in space significantly reduce sublimation rates.
  • A participant proposes that sublimation requires a continuous heat source, which is provided by the Sun, and discusses how the sublimation rate is influenced by solar irradiance and heat loss into space.
  • One participant presents a back-of-the-envelope calculation estimating the lifespan of a comet based on its distance from the Sun and its mass, suggesting that comets in the Oort cloud could last much longer than the age of the universe.
  • Another participant refines the discussion by emphasizing the balance between insolation and vapor pressure at varying temperatures, noting that thermal radiation decreases more slowly than vapor pressure, which could affect sublimation rates at low temperatures.
Participants express differing views on the primary factors influencing sublimation rates, with some emphasizing the role of vapor pressure and others focusing on the heat source from the Sun. The discussion remains unresolved regarding the relative importance of these factors.
Participants reference specific temperatures and their effects on vapor pressure and thermal radiation, but the discussion does not resolve the implications of these factors on comet lifespans or sublimation processes.
Individuals interested in astrophysics, cometary science, or the thermodynamics of sublimation may find this discussion relevant.
hexanol
TL;DR
a question regarding sublimation of comets
Having watched a dropped cube of ice sublime to nothing at the bottom of the freezer of my refrigerator in my kitchen over the course of a week, I would like to know why comets don't do this. Presumably the tail is the product of sublimation, but how long can that go on? How can Halley's Comet even still exist? Seems like the vacuum of space would make up for for the reduced temperature that might reduce sublimation. Help me finally get some sleep. What's the story?
Astronomy news on Phys.org
hexanol said:
TL;DR Summary: a question regarding sublimation of comets
The dependence of vapor pressure on temperature is exponential. Your freezer is probably somewhere around -10 to -20 degrees C (250K) whereas space is much much colder. Take a look at this chart of the vapor pressure of ice and compare -20 to the lowest temperature they list (-82C, or 191K), and note that the difference in vapor pressure is almost 4 orders of magnitude.
https://www.lyotechnology.com/vapor-pressure-of-ice.cfm
And this is only at roughly dry ice temperatures. Once you get out to Pluto, the temperature is roughly 40K, and for long period comets it’s even colder. Here’s a paper with ice vapor pressure extrapolations down to colder temperatures of astrophysical and atmospheric relevance:
https://agupubs.onlinelibrary.wiley.com/doi/full/10.1029/2002GL016183
Note that at 165K, you’re down to a vapor pressure of about ##10^{-4}## Pa, or a billionth of an atmosphere, and this is still a much higher temperature than comets encounter for the vast majority of their orbits.
Thank-you!
The vapor pressure issue is true, but in my opinion a bit of a tail wagging the dog way of looking at the issue. Sublimation carries away energy, so it can't happen without a continuous heat source, otherwise the comet cools down to absolute zero. Obviously that heat source is the sun. The sublimation rate is exactly determined by the heat transfer from the sun minus heat radiated into space, times the energy lost to sublimation per unit mass. It's probably a straightforward exercise to lcalculate the lifespan of a comet in a simple example. Back of envelope (someone please check me):
At Earth's distance, solar irradiance is 1,000 w/sq m, which will sublimate about 8,000 kg/yr from a square meter surface. At Pluto's distance it is 1/1000th that, and for a comet hanging out in the Oort cloud at 10,000AU, 1/100,000,000th.
Assuming a spherical cow cylindrical comet of 1,000 sq m cross section, 10 trillion kg, pointed at the sun and at Earth's distance, it would last a million years. In the Oort cloud, much longer than the universe has been around.
We can refine that...
I think that the insolation is the dominating factor at high temperatures and vapour pressure at low temperatures.
Note that the heat radiated into space is proportional to 4th power of temperature. Which means that compared to ice at 273 K, the thermal radiation of ice is halved at around 230 K - which is -43 C. The table gives vapour pressure around 9 Pa, which means about 70 times less than at 0 C. And the thermal radiation is halved again at 193 K - -80 C, which gives 0,05 Pa. Which is 180 times less. This kind of exponential decrease of vapour pressure, and therefore the rate of evaporation and latent heat expenditure, far faster than radiation that only falls off with fourth power of temperature, means that at a sufficiently low incident light, most of it will be radiated and the evaporation falls exponentially.
For a derivation in the example of mercury, see:
https://www.physicsforums.com/threads/what-would-happen-to-a-blob-of-mercury-in-space.949070/
Thanks everyone for a great discussion of this.
  • · Replies 16 ·
