Find Direct Common Tangent of 2 Circles without Complexity
The discussion focuses on finding a direct formula for calculating the direct common tangent of two circles without resorting to the traditional method of deriving separate tangents. The solution involves adjusting the radius of the larger circle by the radius of the smaller circle, allowing for the determination of the tangent angle using the distance between the centers of the circles and the difference in their radii. This method simplifies the process of identifying tangent points on both circles.
  • Understanding of basic circle geometry
  • Familiarity with tangent lines and their properties
  • Knowledge of coordinate geometry
  • Ability to manipulate geometric equations
  • Study the derivation of tangent lines in circle geometry
  • Explore the concept of shrinking and expanding circle radii
  • Learn about the geometric properties of tangents from external points
  • Investigate the application of trigonometry in circle-related problems
Mathematicians, geometry students, and educators seeking efficient methods for calculating tangents between circles will benefit from this discussion.
Dumbledore211
Is there any direct formula for calculating the direct common tangent of two circles without having to go all the trouble of using y-y1=m(x1-x2) to derive it for two separate tangents t1 and t2. If there is could anyone explain to me how it is derived?
Mathematics news on Phys.org
How would you draw those common tangents?
The problem can be reduced to the problem of drawing tangent from a point. Shrink (or blow up) the radius of the bigger circle by the radius of the smaller one. The tangent to the new circle from the centre of the smaller circle e is parallel to tangent line t.
It is easy to get angle theta from the distance of the centres (d) and the difference of the radii. Write up the equation of the green lines. They intersect the tangent points on the circles.
ehild
