Communicating Vessels- how? (searched forum, didn't find it before)
  • Thread starter Thread starter Bonaparte
    Forum
The discussion revolves around the physics of communicating vessels, specifically how water behaves in two connected containers with different radii. The key point is that while the right container has more mass due to its larger radius, the pressure exerted by the water is determined by depth, not mass, leading to equal pressure at the connection point. This results in no net movement of water between the vessels when they are at equilibrium. The forces from both containers balance each other out, confirming that the water levels will remain stable unless an external force is applied. Understanding these principles clarifies why the water does not rise or move in a circular motion as initially proposed.
Bonaparte
I don't know much about physics, I'm using-
F=m*a
So say we got our 2 containers with a straight passage between them (they're cylinders for the sake of the question), and the right one has double the radius.
So I'm assuming there are 2 forces pushing each other (in the passage), one from the weight of the right container, and one from the left.
The right one has more mass (assuming they've got equal height of water which is basically what communicating vessels say). Wouldn't it be "pushing" the water in the passage with more force?
If it does, does it cause a circular motion of water on the other side? Otherwise why doesn't it rise?
As stated above I'm proposing the motion of water moving in a circular motion on the left container.
As a side note, might be negating myself, but when I'm water pushes down other water (say in the right container, water is pressing the water under it, which is next to the passage), does it push the water to the sides?
Thanks in advance.
http://assets.overclock.net.s3.amazonaws.com/1/17/1721d4ed_vbattach152018.png here's a picture to help understand my question.
Let me check: Under 1) problem, there is no problem but a statement. Under 2) relevant equations there is a partial problem statement and a question and under 3) there is a proposal and a question.
Suppose I want to help, what can you do to help me help you (except: get organized and use the template properly) ?
Hello and thanks for the response, seems I can't edit the post.
The question is in the title, I don't know any equations other than the one given, you'll have to forgive it being in the wrong place.
My proposal does not include a question, it's a proposal that is phrased as one.
Cheers.
PF allows you do do a little editing for a while, then it fixates. You can add stuff in subsequent posts, though.
So the question is more or less: what is the equilibrium condition if two vessels are connected by some means.
Well, equilibrium means the water in the connection isn't moving. Water moves under pressure difference. The weight in the right vessel is bigger than in the left, but the bottom area is also bigger. So the force (mg) per area is the same (if the liquids are at he same levels). Pressure is only dependent on how deep you are. 0.5 m deep in the ocean is not different from 0.5 m deep in your bath (with some bath salt ;-) )
That means that in de connection the forces from left and right vessel are equal and opposite: they cancel and ##\sum F=0##: no movement
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
