Communicating at Near-Light Speed - Time Dilation
This discussion explores the impact of time dilation on communication at relativistic speeds, specifically at 99% of the speed of light. It highlights that a moving observer, such as the Flash or a spaceship, experiences time differently than stationary observers, leading to the perception of slower communication due to the relativistic Doppler effect. The Lorentz factor at this speed is approximately 7, which is crucial for understanding the necessary adjustments in communication frequency. The conversation emphasizes the importance of visualizing these effects through spacetime diagrams to grasp the nuances of periodic transmissions and the transverse Doppler effect.
  • Understanding of time dilation and the Lorentz factor
  • Familiarity with the relativistic Doppler effect
  • Basic knowledge of spacetime diagrams
  • Concept of periodic signal transmission
  • Study the Lorentz transformations in detail
  • Learn about the relativistic Doppler effect and its applications
  • Explore spacetime diagrams and their significance in relativity
  • Investigate the concept of transverse Doppler effect in various scenarios
Physicists, students of relativity, and anyone interested in the implications of high-speed communication in theoretical physics.
SF Alba
So, I've been wondering: how would time dilation affect communications?
For the sake of visualisation, imagine the Flash is running at 99% the speed of light in a circle around a fixed position. There's a building in this position, and inside this building are his friends. Due to time dilation, they should be experiencing time at different rates. Assuming the usual problems(wind muffling comms, drag etc.), are a non-issue, and that he is talking to his friends through conventional radio communications, would others perceive him to be talking much slower than normal, if, from his perspective, he was talking at a normal rate? If so, at what rate would he have to talk to be able to communicate with them?
If you'd prefer, you can swap the Flash for a spaceship and the building for an asteroid; like I said, it's just to help with visualisation.
Well, to start off, his friends would have to tune their receiver differently as the radio signal would be affected by relativistic Doppler shift. Exactly what would be observed depends on the direction the Flash is running in.
Taking the spaceship case, the Lorentz factor for 99% of c is about 7. You take it from there.
Draw a spacetime diagram with a sequence of periodic transmissions.
Note the receptions.
As mentioned by @Orodruin , this involves the Doppler Effect.
Seriously, do this.
Signalling between circular moving observer and observer at the center of the circle (presumed inertial) is a special case . The situation is stationary with a lot of symmetry (rotation, time translation). Using this, the exact answer can be written down with virtually no computation or diagramming. Nor do you need to worry about Doppler.
After the fact, it is interesting to explain both observers' point of view with proper application of Doppler, helping understand the nuances of transverse Doppler.
  • · Replies 23 ·
  • · Replies 18 ·
  • · Replies 47 ·
  • · Replies 46 ·
  • · Replies 65 ·
12K
  • · Replies 27 ·
  • · Replies 45 ·
  • · Replies 27 ·
