Commutation relations trouble (basic)
5 replies · 3K views · last reply
I am reading the first chapter of Sakurai's Modern QM and from pages 30 and 32 respectively, I understand that
(i) If [A,B]=0, then they share the same set of eigenstates.
(ii) Conversely, if two operators have the same eigenstates, then they commute.
But we know that [itex][L^2,L_z]=0[/itex], [itex][L^2,L_x]=0[/itex] and [itex][L_z,L_x]\neq 0[/itex].
From the first equality, and (i) I gather that L² and L_z have the same eigenkets. From (i) and the second equality, I get that L² and L_x have the same eigenkets. So L_z and L_x have the same eigenkets. Hence, by (ii), they commute, which contradicts [itex][L_z,L_x]\neq 0[/itex].
Where did I go wrong??
Hi quasar,
Consider the states [tex]| \ell, \,m_z \rangle[/tex] which are the usual simultaneous eigenstates of [tex]L^2[/tex] and [tex]L_z[/tex]. To understand your problem, imagine taking superpositions of these states with the same [tex]\ell[/tex] but different [tex]m_z[/tex] values. For example, the state [tex]| 1/2,\, 1/2 \rangle + | 1/2, \,-1/2 \rangle[/tex] is such a superpostion; an equal superposition of spin up and spin down. This state is not an eigenstate of [tex]L_z[/tex] (two different [tex]m_z[/tex] values), but it is still an eigenstate of [tex]L^2[/tex]. Thus while it is certainly possible to choose simultaneous eigenstates of [tex]L_z[/tex] and [tex]L^2[/tex], it is definitely not true that every eigenstate of [tex]L^2[/tex] is an eigenstate of [tex]L_z[/tex]. In fact, the state I just constructed is nothing other than the spin up eigenstate of [tex]L_x[/tex]. That is, it is a simultaneous eigenstate of [tex]L^2[/tex] and [tex]L_x[/tex] rather than [tex]L^2[/tex] and [tex]L_z[/tex]. So you see, among all the states with the same value of [tex]\ell[/tex], there is a nontrivial freedom to construct states that are eigenstates of [tex]L_z[/tex] or [tex]L_x[/tex]. Finally, the fact that [tex]L_z[/tex] and [tex]L_x[/tex] don't commute simple means that you won't be able find to find linear combinations which are eigenstates of [tex]L_z[/tex] and [tex]L_x[/tex].
Hope this helps!
Ah, so I misinterpreted (i). Would a true statement be that if [A,B]=0, then the eigenkets of either one of A or B are eigenkets for the other.
Correct? Can it be made stronger?
The crucial point is that the above statement is definitely not true; eigenstates of A are in no way guaranteed to be eigenstates of B. The guarantee you do have is much weaker. What it says is that if you make a list of linearly independent eigenstates of A with the same eigenvalue, then you can always make from this list states which are also eigenstates of B (provided A and B commute). Again, it does not mean that every state on your list is automatically an eigenstate of B, only that you can find some combinations which are.
Technically, if [itex]A:D(A)\rightarrow \mbox{Im}(A)[/itex] ,[itex]A:D(B)\rightarrow \mbox{Im}(B)[/itex] AND [itex]D(A) \cap D(B) \neq \emptyset[/itex], then
[tex]AB-BA=0 \Leftrightarrow A(B\psi)=B(A\psi), \forall \in \psi D(A) \cap D(B) \ \mbox{and} \ B\psi \in D(A) , A\psi \in D(B)[/tex].
Daniel.
