Commutative Monoid and some properties
  • Level: Graduate
  • Thread starter Kindayr
    Properties
48 replies · 10K views · last reply
Kindayr
For reference, let [itex]\mathbb N^{\infty}[/itex] denote the set of all [itex]\infty[/itex]-tuples of the form [itex](n_{1}, n_{2}, \dots)[/itex] with [itex]n_{i}\in \mathbb N ,\,\forall i[/itex], and let [itex]\mathbb N^{*}=\{1,2,3,\dots\}[/itex].
Let [itex]n\in\mathbb N^{*}[/itex]. Then by the Fundamental Theorem of Arithmetic, we can represent [itex]n[/itex] as a unique factorization of primes. That is [tex]n=p_{1}^{e_{1}} p_{2}^{e_{2}}\cdots=\prod_{k=1}^{\infty} p_{k}^{e_{k}}.[/tex] Define a function [itex]\phi :\mathbb N^{*} \to \mathbb N^{\infty}[/itex] such that [itex]\phi(n)=(e_{1},e_{2},\dots)=(e_{k})_{k=1}^{\infty}[/itex]. Further, define a binary operation [itex]\oplus:\mathbb N^{\infty}\times\mathbb N^{\infty}\to\mathbb N^{\infty}[/itex] such that [tex]\oplus((a_{1},a_{2},\dots),(b_{1},b_{2},\dots))=(a_{1}+b_{1},a_{2}+b_{2},\dots).[/tex]
I will now show that [itex](\mathbb N^{\infty},\oplus)[/itex] is a commutative monoid.
  • Let [itex]u,v\in\mathbb N^{\infty}[/itex] with [itex]u=(a_{k})_{k=1}^{\infty}[/itex] and [itex]v=(b_{k})_{k=1}^{\infty}[/itex]. Then [itex]u\oplus v=(a_{k}+b_{k})_{k=1}^{\infty}=(b_{k}+a_{k})_{k=1}^{\infty}=v\oplus u[/itex]. Since [itex]a_{k}+b_{k}=b_{k}+a_{k}\in\mathbb N,\,\forall k[/itex], it follows that [itex]u\oplus v=v\oplus u\in\mathbb N^{\infty}[/itex]. So [itex](\mathbb N^{\infty},\oplus)[/itex] is both closed and commutative, as required.
  • Let [itex]u,v,w\in\mathbb N^{\infty}[/itex] with [itex]u=(a_{k})_{k=1}^{\infty}[/itex],[itex]v=(b_{k})_{k=1}^{\infty}[/itex] and [itex]w=(c_{k})_{k=1}^{\infty}[/itex]. Then [itex](u\oplus v)\oplus w=((a_{k}+b_{k})+c_{k})_{k=1}^{\infty}=(a_{k}+(b_{k}+c_{k}))_{k=1}^{\infty}=u\oplus (v\oplus w)[/itex]. Thus [itex](\mathbb N^{\infty},\oplus)[/itex] is associative.
  • Let [itex]1_{\mathbb N^{\infty}}\in\mathbb N^{\infty}[/itex] such that [itex]1_{\mathbb N^{\infty}}=(0,0,\dots)[/itex]. Then for any [itex]u=(a_{k})_{k=1}^{\infty}\in\mathbb N^{\infty}[/itex], we have [itex]1_{\mathbb N^{\infty}}\oplus u=(0+a_{k})_{k=1}^{\infty}=(a_{k})_{k=1}^{\infty}=(a_{k}+0)_{k=1}^{\infty}=u\oplus 1_{\mathbb N^{\infty}}[/itex]. Thus, [itex]1_{\mathbb N^{\infty}}[/itex] is the identity element of [itex](\mathbb N^{\infty},\oplus)[/itex].
Thus, [itex](\mathbb N^{\infty},\oplus)[/itex] is a commutative monoid.
Now I will show that [itex]\phi[/itex] is a commutative monoid homomorphism.
  • Let [itex]a,b\in\mathbb N[/itex]. Then by the Fundamental Theorem of Arithmetic, both [itex]a[/itex] and [itex]b[/itex] have a unique factorization of primes. That is [itex]a=\prod_{k=1}^{\infty} p_{k}^{e_{k}}[/itex] and [itex]b=\prod_{k=1}^{\infty} p_{k}^{f_{k}}[/itex]. Then [itex]ab=\prod_{k=1}^{\infty} p_{k}^{e_{k}+f_{k}}[/itex]. So we have [itex]\phi (ab)=\phi (\prod_{k=1}^{\infty} p_{k}^{e_{k}+f_{k}})=(e_{k}+f_{k})_{k=1}^{\infty}=(e_{k})_{k=1}^{\infty}\oplus (f_{k})_{k=1}^{\infty}=\phi(a)\oplus\phi(b)[/itex], as required.
An interesting result to is to show that [itex]\phi[/itex] is actually a commutative monoid isomorphism. I leave this up to the reader.[EDIT: THIS IS INCORRECT IF WE'RE WORKING WITH [itex]\mathbb N^{\infty}[/itex]]
I've been messing around with this, and you can get some pretty cool new operations on numbers. Now that they are "basically" vectors, you can start making new operations like dot product, tensor product, their 'length' with respect to different norms. My favourite so far has been showing a homomorphism from [itex]\mathbb N^{\infty}\to\mathbb P[x]^{\infty}[/itex], the set of all polynomials with one variable. Once this is done, you can create a new binary operation such that you take two numbers from [itex]\mathbb N^{*}[/itex], convert both separately by [itex]\phi[/itex] to [itex]\mathbb N^{\infty}[/itex], then to [itex]\mathbb P[x]^{\infty}[/itex], and do normal polynomial multiplication, then convert that polynomial all the way back to [itex]\mathbb N^{*}[/itex].
I also feel (severely speculative), if you can figure out some way with all these new operations to define a homomorphic addition within [itex]\mathbb N^{\infty}[/itex], we could find a simpler solution to Fermat's Last Theorem.
You can also play around with it more finitely, which I can explain a bit later, but my fingers are tired from typing.
If you have input, or come up with your own results, or have criticisms, please contribute! I would like to see if these definitions bring out anything cool.
geez, I wish I had seen that before typing all that up.
An isomorphism would exist if you worked in [itex]\mathbb Z_{p}[/itex] instead? That is, pick a prime [itex]p[/itex], and for all primes [itex]1<p_{1}<p_{2}<\cdots<p_{n}=p[/itex], we can define an isomorphism [itex]\phi:\mathbb Z_{p}\to\mathbb Z_{p}^{n}[/itex] such that if [itex]a\in\mathbb Z_{p}[/itex] then [itex]\phi(a)=(e_k)_{k=1}^{n}[/itex] where [tex]a=\prod_{k=1}^{n}p_{k}^{e_{k}}.[/tex] Wouldn't [itex]\phi[/itex] even be a commutative group isomorphism?
Maybe I even want [itex]p_{n}<p[/itex]? I have to think about this more and make it more rigourous.
Thank you for the link though!
You mean to say [itex]\mathbb{Z}_p^*\rightarrow \mathbb{Z}_p^n[/itex], right?? Well, that could work. I suggest you try to prove it!
In general, something that might work is [itex]\mathbb{N}^{(\infty)}[/itex]: that are all the tuples [itex](n_1,n_2,n_3,...)[/itex] such that only a finite number of terms are nonzero. You'll have better luck proving that an isomorphism.
Also, there is no need to work with [itex]\mathbb{N}[/itex] for this. You can also do the same thing for [itex]\mathbb{Q}[/itex]. So we can define a map
[tex]\mathbb{Q}^*\rightarrow \mathbb{Z}^{(\infty)}[/tex]
This are some things you should ponder on. But the OP was verry interesting!
Thanks for the help!
And yes, I did mean [itex]\mathbb Z_{p}^{*}\to\mathbb Z_{p}^{n}[/itex]. That fixes the problem that caused me to ask if we should have [itex]p_{n}<p[/itex].
I also want to give an example of what I meant with the polynomials. I don't want to type out the entire definition of the operation I'm going to use, but I hope the example gives light to it:
[tex]6\otimes8\simeq(1,1,0,\dots)\otimes'(3,0,0,\dots) \simeq (1+x)(3)=3+3x\simeq(3,3,0,\dots)\simeq 2^{3}3^{3}=8\times 27=216.[/tex]
This operation can also be shown to be commutative. However in this case, [itex](0,0,0,\dots)[/itex] acts as a 'absorbing' element, not unlike [itex]0[/itex] with respect to [itex](\mathbb Z,\cdot)[/itex].
I haven't done any group theory or abstract algebra officially, this is all just what I'm starting to pull from Artin's Algebra. I really like it so far :)
I'll also work on that isomorphism.
Also, could that operation be used in cryptography?
Hmmm, that polynomial thing is quite interesting. I've not yet encountered such a thing, but it reminds me in some way of group rings. It should be worth studying your operation in that context.
The interesting part is that the 'product' of any two primes, results in another prime. I thought that was cool.
Fix [itex]p[/itex] prime. We can define a function [itex]\parallel\cdot\parallel_{\phi_{p}}:\mathbb N^{*}\to\mathbb R[/itex] such that for all [itex]a\in\mathbb N^{*}[/itex], we have [tex]\parallel a\parallel_{\phi_{p}}=\,\parallel \phi(a)\parallel_{p}.[/tex] This can give us a sense of 'length' that each number has. For example: [tex]\parallel6\parallel_{\phi_{2}}=\,\parallel \phi(6)\parallel_{2}=\parallel (1,1,0,\dots)\parallel_{2}=\sqrt{2},[/tex][tex]\parallel 8\parallel_{\phi_{2}}=\,\parallel \phi(8)\parallel_{2}=\parallel(3,0,\dots)\parallel_{2}=3,[/tex]and[tex]\parallel 7\parallel_{\phi_{2}}=\,\parallel \phi(7)\parallel_{2}=\parallel (0,0,0,1,0,\dots)\parallel_{2}=1.[/tex]Note that [itex]6<7[/itex] but [itex]\parallel7\parallel_{\phi_{2}}<\parallel6\parallel_{\phi_{2}}[/itex].
I've also thought about making an encryption algorithm changing letters to irreducible polynomials over [itex]\mathbb N^{*}[/itex] using my operation I defined in one of the earlier posts. You could even go further to making words map to matrices in RCF, or something like that. I know nothing about cryptography though ahahah.
We can even make a sort of inner product of in [itex]\mathbb N^{*}[/itex] and fool around in there. For example, [tex]\langle6,8\rangle_{\phi}=\langle(1,1,0,\dots),(3,0,0,\dots)\rangle=3.[/tex]Note that we could show that all primes are orthogonal to one another.
What if you defined [itex]\mathbb{N}^\infty[/itex] as the set of all (countably) infinite sequences with only finitely many nonzero entries...
micromass already mentioned that I believe, and I'm using that criterion for [itex]\mathbb N^{\infty}[/itex] in the paper I'm writing to show this to a professor of mine who I hope to help me push out some cool results.
Argh, I completely missed that post when I skimmed the thread. :frown:
No worries! I'm no less thankful for your input. Its something that allows a lot of this to hold, and I completely missed it when I was defining things originally. I've uploaded my paper so far, I'm adding and proof reading it as I go along and discover new things. I haven't added the new 'length' idea, nor the 'inner product' stuff.
Interesting paper!
Allow me to make some remarks:
- in Theorem 2, you can even show injectivity. So these things are a submonoid.
- Prime factorizations exist over the rationals too, for example: 5/6=[itex]2^{-1}3^{-1}5[/itex]. So your map phi generalizes to
[itex]\phi:\mathbb{Q}^*\rightarrow \mathbb{Z}^\infty[/itex]
- There is a small problem with the definition after theorem 2. The thing [itex]\sum{a_kx^k}[/itex] is NOT a polynomial. Indeed, polynomials have only a finite amount of terms. However, it is a formal power series. So you need [itex]\psi[/itex] to go the the formal power series.
micromass said:
Interesting paper!
Thank you very much micromass!
If I generalize [itex]\phi:\mathbb{Q}^{*}\to\mathbb{Z}^{\infty}[/itex], does this not also give me a group?
Also, if I define [itex]\mathbb{P}[X]^{\infty}[/itex] to be the single-variable polynomials with only a finite amount of nonzero coefficients, would this fix the problem arisen in your third point?
Also, the thing you posted will not be a norm of course, since it won't satisfy it's properties. Here's something you can do to save it
Let [itex]\Phi:\mathbb{Q}^*\rightarrow \mathbb{Z}^{(\infty)}:q\rightarrow (q_1,q_2,...)[/itex]
For example [itex]\Phi(5/6)=(-1,-1,1,0,0,0,...)[/itex]
Try to define a norm like
[tex]\|q\|=\sum_{i=1}^{+\infty}{2^{-q_i}}[/tex]
I guess this would define a norm if you also define [itex]\|0\|=0[/itex].
My inspiration of course comes from the p-adic numbers...
Yes, I believe so!
Yes.
I'm just confused here how my 'norm' doesn't work :(
I'm just taking any [itex]n[/itex], bringing it to [itex]\mathbb{N}^{\infty}[/itex], and taking the Euclidean norm.
I think you mean [itex]\|1\|=0[/itex], since [itex]0\notin\mathbb{Q}^{*}[/itex]
Well, it might work. But you need to prove that
[itex]\|\alpha x\|=|\alpha|\|x\|~\text{and}~\|x+y\|\leq \|x\|+\|y\|[/itex]
I think you mean [itex]\|1\|=0[/itex], since [itex]0\notin\mathbb{Z}^{*}[/itex]
No, I meant what I said. Of course 0 is not in there, but I put it in there. The reason is that we want to have a vector space, and 0 needs to be an element of the vector space.
Of course, you don't NEED the norm properties, but it would be nice to have them...
But wouldn't [itex]1[/itex] be the zero of the vector space since [tex]\Phi(1)=(0,0,\dots).[/tex] And by your norm, wouldn't [tex]\|1\|=\sum^{+\infty}_{i=1}2^{-q_{i}}=1+1+\cdots=+ \infty[/tex].
Just to add too, if we are trying to get a vector space, then would the [itex]\oplus[/itex] generalized to [itex]\mathbb{Z}^{\infty}[/itex] be vector addition, and exponentiation in [itex]\mathbb{Q}^{*}[/itex] be the scalar multiplication?
Just to add too, if we are trying to get a vector space, then would the [itex]\oplus[/itex] generalized to [itex]\mathbb{Z}^{infty}[/itex] be vector addition, and exponentiation in [itex]\mathbb{Q}^{*}[/itex] be the scalar multiplication?
That's nice, but I doubt that this will give you an actualy vector space...
Remember that a vector space must be defined over a field. So I'm not sure what your scalar multiplication will be?
As an aside, one particular application of your map is to show that Peano arithmetic is powerful enough to talk about sequences of natural numbers of arbitrary (finite) length. (e.g. this is a major part of the technical content of the proof of Gödel's incompleteness theorems)
Choose our field to be [itex]\mathbb{Z}[/itex]. Then let [itex]\alpha\in\mathbb{Z}[/itex] and [itex]q\in\mathbb{Z}^{\infty}[/itex] with [itex]q=(q_{1},q_{2},\dots)[/itex]. Then [itex]\alpha q=\alpha (q_{1},q_{2},\dots)=(\alpha q_{1},\alpha q_{2},\dots)[/itex]. Note that this isomorphic to exponentiation of rationals by integers. That is, let [itex]p\in\mathbb{Q}^{*}[/itex] and [itex]n\in\mathbb{Z}[/itex]. Then [itex]\Phi(p^{n})=(np_{1},np_{2},\dots)[/itex].
That's not a field :frown: You would end up with a [itex]\mathbb{Z}[/itex]-module, which is also cool. But you wouldn't have a normed space...
Whoa, could you please explain? I haven't been exposed to much of any metamathematics. And I find this super interesting, because a lot of ideas of this came from me working with Peano Spaces, and trying to find a difference between primes and composite numbers. My previous discussion could be found https://www.physicsforums.com/showthread.php?t=521157".
Thank you all for your help so far though!
What if we work in [itex]\mathbb{Z}^{n}_{p}[/itex] over a the field [itex]\mathbb{Z}_{p}[/itex], as I discuss in the second part of my paper? This gets a bit messy I guess though.
Aaah, that might work :smile:
Then I will play around with that tonight, and type some stuff up tomorrow! I'll try to generalize everything using the map you defined, and see what I can do.
thank you very much micromass!
I'm just trying to find a way to work this.
Fix [itex]p[/itex] prime. Let [itex]1<p_{1}<p_{2}<\cdots<p_{n}<p[/itex] be all primes between [itex]1[/itex] and [itex]p[/itex], and let [itex]\mathbb{Z}_{p}^{n}[/itex] be the set of all [itex]n[/itex]-tuples with entires in [itex]\mathbb{Z}_{p}[/itex]. Then our map [itex]\Phi[/itex] doesn't work since we can find a [itex]q\in\mathbb{Q}^{*}[/itex] whose factorization uses a prime [itex]p_{0}>p[/itex].
So that's just where I'm confused.
I'm just trying to get over a slump on how to turn this into a vector space.
Once you have a data structure, you can do a lot. Just look at set theory. :smile:
Similar power is opened up to you once you can view an integer as a list of integers.
There are a variety of related things, I'll go down the route of computability -- what is a computer? It is essentially just it's current state -- a list of integers (e.g. the list might contain 16 registers, and the rest be memory which can be interpreted as instructions or data) -- and a rule for advancing from one state to the next.
The hardest part of encoding this in Peano arithmetic is how to use an integer to encode a list of integers, and how to access / manipulate lists under this encoding.
(Then, once you have encoded the state of a computer as a single integer, you can then talk about the execution of a program on a computer as the "list of integers" corresponding to the state of the computer at a given time. With this, you can now start reasoning about how computers behave, again using just Peano arithmetic under-the-hood)
Formal logic is similar -- specifically look at the subfield of syntax, which talks about languages, grammar, and proofs. Here, you want to use a "list of integers" to store the characters in a formal expression -- i.e. to store strings.
There are other ways to manage this technical construction, but I think the isomorphism from your original post is the most straightforward. (it does require you to first prove some things about primes and divisibility, though)
So I typed it up again, generalizing [itex]\phi:\mathbb{Q}^{*}\to\mathbb{Z}^{\infty}[/itex].
I'm still a little confused how to turn this into a vector space. I was wondering, if we use the non-transcendental numbers as our field. But would we lose the fact of 'prime factorization', and the basis of even doing this?
I can't conceptually see how to work in [itex]\mathbb{Z}_{p}[/itex] for some prime [itex]p[/itex]. I don't know how we would chose [itex]p[/itex]. Maybe I'm just obsessing over minor points.
I've also defined [itex]\psi:\mathbb{Z}^{\infty}\to\mathbb{P}[X]^{\infty}[/itex], but I just don't know how to define a binary operation [itex]\otimes:\mathbb{Z}^{\infty}\times\mathbb{Z}^{ \infty}\to\mathbb{Z}^{\infty}[/itex] such that it is homomorphic by [itex]\psi[/itex] to multiplication of finite polynomials.
