Compass Behavior Near Parallel Current-Carrying Wires
  • Thread starter Thread starter Samurai44
    Compass Wires
4 replies · 2K views
Samurai44
two wires are parallel to each other,carries current of same magnitude, and the distance between them is 10cm ,, wire A carries current out of the page ,, Wire B carries current into the page ... A compass is placed at 4 cm from wire A .. Where does the needle point ?
I also would like to know where does the needle will point if the two wires carries same current direction
same current direction - Attraction
opposite current direction - Repulsion
I drew the magnetic field around each wire(Wire A-Anticlockwise ... Wire B-Clock wise) , but since the field is circular around a straight wire , so I couldn't know where it will point exactly .
It will be tangent to the circle at any location around the circle.
so the other wire won't affect the direction of the needle unless the compass was at mid point ?
No, the fields from both wires will sum at any given location (superposition principle). Pick a location and sketch the circles centered on each wire that pass though that point. Sketch in the field vector at that point for each wire. Sum the vectors.
alright thanks
