Complete screening of an Electric field?
The discussion centers on the concept of electric field screening in solids, particularly metals, and its relation to the Thomas-Fermi model. Screening occurs due to the collective movement of free electrons in response to an external electric field, which minimizes energy and negates the field within the material. The participants clarify that screening is complete for static electric fields, while dynamic fields may exhibit varying degrees of screening. Key distinctions are made between screening and related concepts like plasmons and electric field shielding.
  • Understanding of electric fields and their properties
  • Familiarity with the Thomas-Fermi model
  • Knowledge of electron behavior in conductive materials
  • Basic concepts of energy minimization in physics
  • Research the Thomas-Fermi screening model in detail
  • Explore the behavior of free electron gases in metals
  • Study the differences between electric field screening and shielding
  • Investigate the implications of dynamic electric fields on screening effects
Physicists, materials scientists, and electrical engineers interested in the behavior of electric fields in conductive materials and the principles of screening in solid-state physics.
RoseSunflower
Hi,
I have difficulty understanding the term screening.
Screening is reducing of the electric field, as far as I have understood until now.
1. Why does screening occurs? Is it due to collective interaction of plasmons?
2. If we have a slow electric field, will screening occur or will it not occur? Same question for fields that varies a lot.
3. If the electric field is reduced as much as possible, does that means that screening = 0 and that it is complete?
Thank you.
RoseSunflower said:
Hi,
Thank you.
Welcome to the PF. :smile:
Do you mean Electric field shielding, like with a Faraday Cage? https://en.wikipedia.org/wiki/Faraday_cage
Thank you :)
No, actually I am looking at electric field screening for solids (metals). I read Wikipedias page about it but I still don't get it.
If you make a hollow inside a metal block and sit inside it, you are shielded from any electric fields outside. For a static electric filed, the screening is complete.
Could you answer my questions as in 1, 2 and 3? I don't understand where the hollow comes from. And when the screening is complete.
OK. We may be talking of totally different things. Could you please desctibe what you mean by the word "screening?". Perhaps if you could give us the reference to the Wikipedia pages you have read, we could get the context.
I am looking at electric field screening for solids (metals). Thomas-Fermi screening. I don't know if its the same or two different things though...
Thanks. This is a topic on which I have no views.
No, plasmons are something else, this deals primarily with, e.g., the free electron gas in a metal. An externally applied electric field causes electrons to move around in such a way as to minimize the energy in the bulk. The configuration of electron density is such that the externally applied field becomes negated on the other side of this layer. An analogous thing happens to a charge that is introduced into the solid. A change of density in a spherical layer forms to counteract it. These are the screening effect that you are referring to.
  • · Replies 16 ·
