Complex Analysis-Analytic Continuation
  • Thread starter Thread starter WannaBe22
    Complex
WannaBe22
A function f is analytic in the whole complex plane beside 4 poles.
We know that -1,2,1+5i are poles of f and that f gets only real values in (-1,2).
Find the fourth pole of f and show that f is a real-valued function for every real z which isn't a pole.
I've tried using the symmetry principle but without any success..
Help is needed
Thanks !
What symmetry principle did you try to apply and in what way didn't you succeed?
The symmetry principle I've tried using is:
Let [tex]R_1[/tex] be a region located in one side of the real axis and let's assume that the open segment L of the axis is a part of the boundary of [tex]R_1[/tex].
Let [tex]f_1[/tex] be an analytic function in [tex]R_1[/tex] , continuous in [tex]R_1 U L[/tex] and gets real values in L. Let [tex]R_2[/tex] be the symmetric region of [tex]R_1[/tex] according the real axis. If we'll look at the region [tex]R=R_1 U L U R_2[/tex] and we'll define a function f by:
f(z) = [tex]f_1(z)[/tex] when z is in R1UL and
f(z) = [tex]\bar{ f_1(\bar{ z } ) }[/tex]
then f is analytic in R.
I've tried defining "a" to be the fourth pole and looking at L={(x,0) | -1<=x<=2 } ... I can't figure out how to continue from this point... It's obviously the goal of this question, but I'm pretty much stuck...
Hope you'll be able to help me
Thanks !
Take your f in the symmetry principle to be the original f restricted to the upper half plane. What can you say about the behavior of the extended function near the complex conjugate of 1+5i?
Well... By the symmetry principle I've quoted above we know that:
[tex]1-5i = \barf(1+5i)[/tex] , and for that reason, 1-5i is a pole of the new extanded function... But because f is analytic, we know that [tex]\barf(\barz) = f(z)[/tex] in the lower half plane, and for that reason-1-5i is also a pole of our f...
As for the second part of the question-
We can look at [tex]\Omega = C - (1-5i,1+5i,-1,2)[/tex] , then both f and
[tex]\bar f (\bar z )[/tex] are analytic in [tex]\Omega[/tex] and agree on (-1,2).
Hence by the identity theorem we can deduce that they are the same in the whole plane, which means that f gets real-values in the real-axis...
Am I right?
Thanks !
Am I right?
Thanks !
Some of your texing isn't coming out right, like /barf but yes, if 1+5i is a pole the 1-5i must also be a pole. To show f(a) must be real if a is real, let z approach a from the upper and lower half planes and consider the limits of your two functions. What does that tell you about f(a)?
