Complex Analysis of a trigonometric function integral
badphysicist
Find I = \int_0^{2\pi} \frac{1}{cos\phi+b} d\phi
Given above..
This problem is an introductory problem to trigonometric functions and here is how the answer is obtained - but I have a question about it. First, here is the solution.
Use complex analysis. Make the substitution z=e^{i\phi} and cos\phi=\frac{e^{i\phi}+e^{-i\phi}}{2} to get \frac{1}{i}\oint_C {\frac{1}{z^2+2bz+1}dz} integrated over the unit circle contour.
We now find the poles: z_\pm=-b\pm \sqrt{b^2-1}.
However, as b goes to infinity, you see that the z_- goes to -infinity and z_+ goes to 0. Obviously, only z_+ stays inside the unit circle for |b|>1 so the solution is:
\frac{2\pi}{\sqrt{b^2-1}}
This is fine and I have no problem with this. This only applies for |b|>1 though. What about for |b|<=1? Well, obviously the integral diverges if you look back at the original integral. Here's my problem - if you try to use contour integration for |b|<=1, you will have to include the residues of both poles because both poles will be on the unit circle as b decreases. Wouldn't the residues cancel giving an answer of zero? What if b is actually a function and you want to do further integrations afterward with respect to a different variable? Thanks for any help on this.
I think you have to consider the cases b&gt;1 and b&lt;-1 separately.
(1) When b&gt;1 :
The pole at z=-b- \sqrt{b^2-1}&lt;-1 lies outside the unit circle, while the pole at z=-b+ \sqrt{b^2-1}= \frac{1}{-b- \sqrt{b^2-1}}, since \left| \frac{1}{-b-\sqrt{b^2-1}} \right|&lt;1, is enclosed by the unit circle, where we have used the fact that the product of the roots of the equation z^2+2bz+1=0 is 1.
Thus the required pole in this case is z=-b+ \sqrt{b^2-1}.
(2) When b&lt;-1 :
The pole at z=-b+ \sqrt{b^2-1}&gt;1 lies outside the unit circle, while a similar argument to the above shows that the pole at z=-b- \sqrt{b^2-1} lies within the unit circle.
Thus there would be two general solutions, corresponding to the cases b > 1 and b < -1.
As for extending the integral to the case \left| b \right| \leq 1, I think Cauchy's Residue Theorem cannot be applied at all. If, indeed, \left| b \right| \leq 1, then the roots of the equation z^2+2bz+1=0 must be a conjugate pair, and since their product is equal to 1, the modulii of each of the roots is 1. The expression \frac{1}{z^2+2bz+1}dz} is therefore not analytic on the contour of integration, and so we cannot apply the residue theorem in this case.
The last question seems a little open-ended. There are probably very many possibilities, and the most suitable methods of integration in each case may vary considerably. Complex integration may not always be the best choice - I guess it all depends on what specific function you are given for b.
I would like to know how to solve integral with complex analysis:
Integrate[Sin[5*x]/Sin[x], {x,0,2*Pi}] !
I made substitution, get poles +1 and -1, but residue came 0.
Please help!
I have an exam in one week and I really have to know this!
Complex Analysis of Branch Cut
I am trying to figure out the following homework questions:
1 a. Say what it means to define a branch cut for log z. Define a branch for log z and give the location of the branch cut. Note make your definition appropriate for part b.
1b. Find integral [0,inf] {(logx)^4}/{1+x^2 } dx =
Do I have to divide the countour to 3 different path and integrate from there?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
