Complex Analysis: Two Questions About Non-Constant Analytic Functions
arthurhenry
Two questions:
1)Quote comes from a textbook:
Each non-constant function analythic function with f(0)=0 is,in a small nbhd of 0, the composition of a conformal map with the nth-power map...The proof is given and I think I am comfortable with it..
My question is a lot simpler (I think): Can we say the same for a function such that f(a)=b?
I am kindly asking someone to explain why one loses no generality if we
assume a=b=f(a)=0.
2) If an analytic function is not zero in a nbhd, what can I say about the derivative there? i.e. what restriction does this impose on f' (f prime)
Around a circle that lies in the nbhd above we should have
# Zeros=Integral (f'/f)=0
Should this not say f'=0 on that circle?
Thank you
1) If f(a)=b, then f(z) looks like b+(z-a)^n near a.
2) Could you explain why you think f'=0 on the circle?
I was thinking: if f' were to be never zero, then how can Integral[f'/f] around a circle be zero.
The integral should be zero as f has no zeros inside the circle...Is what I am thinking.
Than you for your time again
The contour integral of a nonzero function can very well be zero. Take for instance f(z)=z-2 and integrate f'/f=1/(z-2) on the unit circle.
Somewhat embarrassing...
Thank you very much for the help
Actually, if f is analytic and 1-1, then f' is not zero; if f'(z) is 0 , then factor:
f(z)-zo=z^k(g(z)) (i.e., use Taylor series, where k is the index of the zero of f ),
and g(z) is analytic and non-zero in a 'hood U of zo (the zeros of an analytic non-constant
function are isolated) . The idea is that these conditions on f allow you to define a local k-th root function
in the ball, and k-th roots are k-to-1, and so in particular not 1-1.Under these conditions , take a
small ball B(z,r) around f(z). This allows you to define a log locally, so that you can
then define a k-th root of g(z) (technically, the ball is simply-connected, and does not
wind around 0). Then you can define a k-th root using the log, and k-th roots are not
1-1; they are actually 1-1. Maybe needs work, but it is late.
