Complex conjugate of a wavefunction
The complex conjugate of a wavefunction, ψ*, is essential in quantum mechanics for calculating probabilities, as it ensures the result is a real number when integrated with ψ. The expression ψ*ψ represents the probability density, indicating the likelihood of finding a particle at a specific position. This relationship is fundamental to the mathematical framework of quantum mechanics, particularly in the context of Hilbert spaces and the bra-ket notation. The discussion emphasizes that while ψ can have arbitrary phases, ψ*ψ provides a consistent method for deriving probabilities. Understanding these concepts deepens the comprehension of quantum mechanics and its mathematical underpinnings.
Muthumanimaran
Let ψ be a wavefunction describes the quantum state of a particle at any (x,t), What does ψ* i.e, the complex conjugate of a wavefunction means? I only know probability of finding a particle is given by ∫|ψ|^2 dx= ∫ ψ*ψ dx But what does ψ*ψ really means? I started learning QM with Griffiths without enough mathematical background, Help me.
As you said, supposing that you have a wave function ψ(x) describing your particle in space, then \int_a^b \psi^*(x)\psi(x)dx is the probability of finding your particle between the points a and b.
It follows that \psi^*(x)\psi(x) is the so called probability density. It is nothing but the function that, when integrated, gives you the probability itself.
Likes 1 person
If you measure the position of the particle, at time t, ψ*ψ(x,t) represents the likelihood that you will find it to be at position x... or more accurately within between x and x+dx.
As for what ψ* means, it's the complex conjugate of the wavefunction... but of course you already know that. If you're looking for a nice intuitive way to interpret the physical meaning of the phase of a wavefunction, then I'm afraid I don't think that there is one.
Likes 1 person
Exactly, this is just how the mathematical formalism of Quantum Mechanics works.
Likes 1 person
you only need \psi^{*} because you need to have a real thing to integrate over to get probability... \psi alone is complex, and also it's arbitrary up to an overall phase... that means that either you take \psi or e^{i \theta} \psi they both are solutions of the same shrodinger equation. As such you must make it real, or you'd have arbitrary probabilities depending on a phase...
One quantity that is for sure real is \psi^{*} \psi and nothing is "lost" from \psi's initial parameters (if for example you write \psi=a+ib the result will contain both a and b...
Another example in which you can see that, is when you have \psi real, where you don't need the complex conjugate and just take the square...
In fact the complex conjugate's "meaning" (mathematical) becomes clearer when you start working on the states in vector spaces... The conjugate appears as a relation between the bras and kets, and thus between the vector and its dual space.
Its got to do with the bra-ket notation:
http://en.wikipedia.org/wiki/Bra–ket_notation
The wavefunction is looked at as the Ket - its conjugate as the Bra - apply a Bra to a Ket and square it to get probabilities - that's the Born rule.
At a deeper level states are not actually Bra's or Kets - they are really operators - what are normally referred to as states have a special name called pure.
At an even deeper level again it is seen states are really what's required so we can work out probabilities of the outcomes of observables - this is the important Gleason's Theorem (the key assumption is what is known as non contextuality you may have heard about):
http://en.wikipedia.org/wiki/Gleason's_theorem
It's a devil of a thing to prove however so its not usually talked about much at the beginning level despite its importance.
There is a variant that is much easier to prove and some people use it as the foundation of QM eg:
http://arxiv.org/pdf/quant-ph/0205039v1.pdf
Anyway that will take you to a pretty advanced level. For now what I would do is get a hold of Ballentine:
https://www.amazon.com/dp/9810241054/?tag=pfamazon01-20
Its mathematically quite a bit more advanced than Griffiths. But hold onto your nerves and give the first 3 chapters a read. You won't likely understand too much of the detail, but, hopefully, fingers crossed, you will get the gist so that things are a lot clearer, and Griffiths will be easier. Once you have finished Griffiths you can move onto Ballentine.
Thanks
Bill
ψ is an element of a Hilbert space; ψ* is an element of it's dual space.
The Dirac bra-ket notation makes use of this: |ψ> is an element of the Hilbert space, and <ψ| is it's dual.
Following the general conventions for vector spaces with an inner product, we have <ψ|ψ> is the inner product, and it generates a real number.
  • · Replies 17 ·
