How to Represent Complex Fractions in LaTeX?
This discussion focuses on representing complex fractions in LaTeX, specifically using the \dfrac command. Two methods are highlighted: \dfrac{ \left ( \dfrac{a}{b} \right ) }{ \left ( \dfrac{c}{d} \right ) } and \dfrac{ ^a / _b }{ ^c / _d }. To create longer middle division lines, users can add LaTeX spaces, such as \; or the non-breaking space "~". The conversation also emphasizes the importance of understanding how spaces function in LaTeX math mode, with specific examples provided for clarity.
  • Familiarity with LaTeX syntax and commands
  • Understanding of the \dfrac command for fractions
  • Knowledge of LaTeX space commands such as \, and ~
  • Basic concepts of mathematical typesetting in LaTeX
  • Research advanced LaTeX spacing techniques, including the use of \! and \quad
  • Explore the physics package in LaTeX for improved typesetting of derivatives and integrals
  • Learn about the differences between regular and non-breaking spaces in LaTeX
  • Investigate additional LaTeX commands for enhancing mathematical expressions
Mathematicians, educators, and students who are involved in typesetting mathematical documents using LaTeX, particularly those looking to improve the presentation of complex fractions and equations.
topsquark
Insights Author
MHB
TL;DR
Exploring different ways to represent a complex fraction using LaTeX
I know of two reasonable ways to represent a complex fraction:
##\dfrac{ \left ( \dfrac{a}{b} \right ) }{ \left ( \dfrac{c}{d} \right ) }##
and
##\dfrac{ ^a / _b }{ ^c / _d }##
What I am wondering is if there is a way to write
##\dfrac{ \dfrac{a}{b} }{ \dfrac{c}{d} }##
by making a longer middle division line?
Thanks!
-Dan
Hey Dan,
One way to make the middle line longer, is to add latex spaces to numerator or denominator.
For instance:
\dfrac{\;\dfrac ab\;}{\dfrac cd}
##\dfrac{\;\dfrac ab\;}{\dfrac cd}##
Sometimes I have to add explicit "~" characters to force spaces in LaTeX, but other times just " " spaces seem to work. I haven't figured out why yet...
Can you give some examples?
Regular spaces are generally used as separator. For instance in \dfrac ab the space is not an actual space, but instead it's a separator. That separator only "becomes" a space, if that is needed to separate both sides. In that case multiple spaces are collapsed to a single space.
If we actually "want" a space where that is not already natural, we have to use one of the latex spaces like:
\! \, \: \; \quad \qquad, which are increasingly wide spaces. The first one is a negative space. The "~" is special in that it creates a non-breaking space, so that it won't "wrap".
Just a quick example:
$$v(t) = L \frac{di(t)}{dt}$$
$$v(t) = L~\frac{di(t)}{dt}$$
The classical example is an integral: $$\int f(x,y) dx dy$$
Often \, is inserted (despite already having spaces) before the infinitesimals to get a more natural formula:$$\int f(x,y)\,dx\,dy$$
A "~" also works of course.
I meant examples of where you would expect a space but there was none.
Compare the following:
\int f(x,y)~dx~dy \qquad \int f(x,y)\,dx\,dy
The non-breaking space ~ is a regular sized space (it is equivalent in size to the regular \ ) as compared to \, which is 3 mu. The latter is typically what you want. The non-breaking space ~ should be used when you have a space where you do not wish to create a (line or page) break. In an equation it is essentially equivalent to the regular space "\ " (which has its own uses in text as well, such as not creating a too large space after an abbreviation, i.e., LaTeX will interpret "cf. last chapter" as there being an end of sentence after cf. whereas "cf.\ last chapter" will not).
In the first LaTeX line, I put a " " space after the L, but it did not render. It took the explicit "~"space after the L to get it to render.
Of course it didn’t, spaces are mostly irrelevant to math mode (for good reason).
For integrals, using the physics package might be helpful to some extent. One may use \dd{} from that package, which manages the spacing automatically, and also makes the d upright.
$$\require{physics}
\int f(x,y) \dd{x} \dd{y}$$
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 20 ·
