Complex Isomorphism Error in Lorentz Transform
11 replies · 2K views
jk22
I felt upon a mistake I made but cannot understand. I consider the following rotation transformation inspired from special relativity :
$$\left(\begin{array}{c} x'\\ict'\end{array}\right)=\left (\begin {array} {cc} cos(\theta) & -sin(\theta) \\ sin(\theta) & cos(\theta) \end {array}\right)\left(\begin{array}{c} x'\\ict'\end{array}\right)$$
Writing the first line gives $$x'=cos(\theta)(x-i tan(\theta)ct)$$
If I want this expression to be like a Lorentz transformation I should have the form $$x'=\gamma(v)(x-vt)$$ hence $$ic tan(\theta)=v \Rightarrow tan(\theta)=-i\frac{v}{c}$$
Then $$cos(\theta)=\frac{1}{\sqrt{1+tan(\theta)^2}}=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}$$ which is the gamma factor.
This gives the usual Lorentz transformation.
The problem arises when I consider the 'isomorphism' $$i\equiv \left (\begin {array} {cc} 0 & -1\\ 1 & 0 \end {array}\right)$$
Indeed I can then write $$e^{i\theta}\equiv \left( \begin {array} {cc} cos(\theta) & -sin(\theta) \\ sin(\theta) & cos(\theta) \end {array}\right)$$
But inserting the value of theta gives : $$\left(\begin {array} {cc} cos(\theta) & -sin(\theta) \\ sin(\theta) & cos(\theta) \end {array}\right)=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}} \left( \begin {array} {cc} 1 & i\frac{v}{c} \\ -i\frac{v}{c} & 1 \end {array}\right)\equiv \sqrt{\frac{1+\frac{v}{c}}{1-\frac{v}{c}}}$$
Which is the Bondi k factor.
Hence using this mapping of $$i$$ to real 2x2 matrices produce an error since we get then an homotethy instead of the Lorentz transform.
Is it because the application mapping of $$i$$ is injective and not bijective ?
Is there a typo above? The input vector is exactly the same as the output vector. From your work below, the vector on the right side should be ##\begin{bmatrix} x \\ ict\end{bmatrix}##
But you seem to be omitting that factor or ##\cos(\theta)## that multiplies ##(x - i\tan(\theta)ct)##.
Thanks, Yes there is a typo i just copied the latex formula for the vector.
But should 't this thread be moved to the relativity forum I was hesitating ?
I have reported this thread to see what some of the other mentors think about moving it there.
robphy said:
Can you show your steps (in the equiv sign) that leads to the Bondi factor?
Indeed it's probably there : $$ \left(\begin{array}{cc} 1 & i\frac{v}{c} \\ -i\frac{v}{c} & 1\end{array}\right)\equiv 1-i\frac{v}{c} \left(\begin{array}{cc} 0 & -1\\ 1 & 0 \end{array} \right)\equiv 1+\frac {v}{c} $$
I think it's right. You don't actually have to use matrices to get the answer.
If [itex]cos(\theta) = \gamma[/itex] and [itex]sin(\theta) = -i \frac{v}{c} \gamma[/itex], then
[itex]e^{i \theta} = cos(\theta) + i sin(\theta) = \gamma + \frac{v}{c} \gamma = \frac{1 + \frac{v}{c}}{\sqrt{1-\frac{v^2}{c^2}}} = \frac{\sqrt{1+\frac{v}{c}}}{\sqrt{1-\frac{v}{c}}}[/itex]
You can get the same result, without the [itex]i[/itex], by writing:
[itex]x' = x cosh(U) - ct sinh(U)[/itex]
[itex]t' = t cosh(U) - \frac{x}{c} sinh(U)[/itex]
where [itex]U[/itex] is the "rapidity", defined in terms of the usual Lorentz parameter, [itex]v[/itex], via:
[itex]v = c tanh(U) \Rightarrow \gamma = cosh(U)[/itex]
Then [itex]e^U = cosh(U) + sinh(U) = \gamma(1+\frac{v}{c}) = \frac{\sqrt{1+\frac{v}{c}}}{\sqrt{1-\frac{v}{c}}}[/itex]
The relationship between [itex]U[/itex] and the [itex]\theta[/itex] in the original post is: [itex]U = i \theta[/itex].
There is obviously something wrong since :
1) the latter calculation with the contraction of the matrices to i gives $$ (x',ict')=\sqrt {\frac {1+\frac {v}{c}}{1-\frac {v}{c}}}(x,ict) $$
2) whereas expanding i into matrices gives $$(x',ict')=\frac {1}{\sqrt {1-\frac {v^2}{c^2}}}(x-vt,i (ct-\frac {v}{c}x)) $$
With (2) we get $$x'^2+(ict')^2=x'^2-c^2t'^2=x^2-c^2t^2$$ but with (1) this quadratic form is not conserved but it appears the factor of contraction.
I thought this comes because the function $$\mathbb {C}\rightarrow M_{2x2}(\mathbb {R}) $$ is injective but not surjective ?
I'm not exactly sure what you're trying to do. You can indeed interpret complex numbers as [itex]2 \times 2[/itex] real matrices. But you're trying to go the other way--interpreting a [itex]2 \times 2[/itex] matrix as a complex number. But then that leaves the column matrices: [itex]\left( \begin{array} \\ x \\ ict \end{array} \right)[/itex] with no matrix to multiply it.
It remains a multiplication by a scalar we can insert a unit matrix if we want
But the whole point of the Lorentz transformations is that you are "mixing up" the x coordinate and the t coordinate when you go to x' and t'. Multiplication by a scalar (or a unit matrix) isn't going to do that.
Indeed. In fact the difference comes from the difference in the equivalence when we use a tensor product when we factorize i :
$$i\otimes i\neq-\mathbb{1}_4$$ when we see i as a 2x2 matrix.
But if we see i as a complex scalar it's -1.
