Is the Shaded Region Outside the Circle in the W Plane?
The discussion revolves around a homework problem involving the transformation of complex numbers from the Z plane to the W plane. The confusion arises regarding the shading of regions, as the participant initially believed that |z| < 3 should indicate shading inside the circle, while the mark scheme shows shading outside. Clarification is provided that |z| < 3 indeed represents the interior of the circle in the Z plane, but the question pertains to the image in the W plane after transformation. Participants are encouraged to verify the transformation by checking points within and outside the circle to understand the resulting regions in the W plane. The transformation leads to the opposite shading in the W plane compared to the Z plane.
trew
[/B]
I had no problems with part a and was able to form the equation of the circle and get its centre/radius.
It's part b that I'm stuck on.
My notes show that for Z < 3 I would shade inside the circle but the mark scheme for this question is showing the circle but the region shaded is OUTSIDE the circle.
Does this have something to do with the transformation into the W plane?
Hello Trew, :welcome:
You can't write ##{\bf z} < 3## for a complex number ... :rolleyes: it's ##|{\bf z}| < 3## as in the problem description.
The latter is inside the circle in the ##\bf z ## plane -- as in your notes
But the exercise asks for the image (the complex 'range') of the function (transformation), so, as you suspect, in the ##\bf w## plane.
Hey BvU,
Appreciate the response and help.
So is it a case of it being the opposite if it is transformed into the W-plane?
You say already found the circle in the W plane ? Check where a pont with ##|{\bf z}| < 3## ends up !
And double check with some points with ##|{\bf z}| > 3## !
24K
  • · Replies 17 ·
