How Can I Estimate Blood Velocity Using Doppler Ultrasound?
This discussion focuses on estimating blood velocity using Doppler ultrasound by designing a bandpass filter to eliminate unwanted high and low-frequency components. The user is implementing this in MATLAB, with a bandpass filter set between 100 Hz and 10,000 Hz. The Fourier transform of the signal is calculated to estimate instantaneous blood speed, but the user encounters issues with obtaining a zero velocity output. Suggestions include creating a simplified example to verify the MATLAB code and understanding the variables used.
  • Doppler ultrasound principles
  • MATLAB programming skills
  • Fourier transform concepts
  • Digital signal processing (DSP) fundamentals
  • Learn about designing bandpass filters in MATLAB
  • Study the implementation of the Fourier transform in MATLAB
  • Explore numerical convolution techniques in signal processing
  • Investigate the effects of noise on signal processing and filtering
Researchers, biomedical engineers, and signal processing professionals interested in non-invasive blood velocity measurement techniques using Doppler ultrasound.
collier
So I am trying to estimate blood velocity using Doppler ultrasound. We have a complex signal y(t)= i (t) + j* q(t). i(t) and q(t) contain unwanted high frequency components created by the demodulation process and low frequency signals that are reflections from stationary tissues. I need to design a bandpass filter to remove these unwanted signals. The higher cutoff frequency of the bandpass filter is can be set at 10000 Hz and the lower frequency at 100 Hz. I am trying to calculate the Fourier transform of y(t) using a time window t(0)-tau<t<t(0) +tau to estimate instantaneous blood speed at t= t(0). This is my MATLAB code so far:
it=xt.*cos(2*pi*f0*t);
ht=9900*sinc((9900)*(t)).*exp(((20000*pi-200*pi)/2+200*pi)*j*t);
ift=conv(it, ht*ts);
qt=xt.*(cos(2*pi*f0*t)-sin(2*pi*f0*t));
qft=conv(qt, ht*ts);
cft(ift, ts,1)
The above is my lowpass filter. Then I used numerical convolution to calculate an approximate output of the filter output i(t) and q(t) when the input is i(t) and q(t) respectively:
for k=1:50
yt=ift+j*qft;
yk =yt(1:length(t)).* ((t>=.02 .*k - .02) - (t>= .02 .*k + .02)) ;
[Yw, w] = cft(yk, ts, 1 ); % calculate the Fourier transform, where
[maxY w_index] = max(abs(Yw)); % find the peak in ||xw||
omega_m(k) = w(w_index); % omega_m(k) is the Doppler shift frequency
end
but when I multiply y(t) by p(t-t0) I get 0 for my w0 and blood velocity is zero everywhere..What am I supposed to do?
Excellent that you are working on this problem. Many years ago, I had a brainstorm while taking a DSP class to create a truly non-invasive blood pressure measurement based on the blood velocity profile using doppler ultrasound . But never pursued it and have moved on to other things, etc.
I can't quite follow your Matlab code as some of the variables aren't quite clear - e.g. what is p(t) at the end? Anyhow, some general suggestions: Create a small scale, hand worked artificial example with known result. First without any noise signals or the filter. Then step through the FFT code to verify the result. Separately, add one low and one high freq sampled sine to the known input and step through the filter code.
Tedious, but nothing verifies like stepping through the code.
Good Luck!
