Complex Square Root Analyticity
The discussion revolves around defining a branch of the multivalued function \( f(z) = (z^2 - 1)^{1/2} \) that is analytic within the unit disk \( |z| < 1 \). Participants explore the implications of branch points at \( z = 1 \) and \( z = -1 \), and the placement of branch cuts for ensuring analyticity.
  • Participants discuss rewriting the function in polar form and the challenges of defining the argument for the branch cut. There are considerations about the placement of branch cuts and their impact on analyticity within the unit disk. Questions arise regarding the implications of different choices for branch cuts and their relation to the function's analyticity.
There is an ongoing exploration of different strategies for defining branch cuts and their effects on the analyticity of the function. Some participants suggest alternative placements for branch cuts, while others seek clarification on the consequences of these choices. Guidance has been offered regarding the nature of analyticity and the role of branch cuts.
Participants are navigating the constraints of the problem, including the requirement for analyticity in specific regions and the implications of branch cuts on the function's behavior. There is an emphasis on understanding the discontinuities introduced by branch cuts and their relevance to the overall problem.
ferret123
Let f(z) denote the multivalued function [itex](z^{2} − 1)^{1/2}[/itex]
Define a branch of f(z) which is analytic in the interior of the unit disk |z| < 1
2. The attempt at a solution
Having a bit of trouble getting started.
I have rewritten f(z) as [itex]((z-1)(z+1))^{1/2}[/itex] as per a hint in the question.
Giving me branch points at z=1 and z=-1 and a branch cut between.
I could rewrite each part in terms of polar representation but there I get stuck on defining which argument to take for my branch.
Any help would be much appreciated.
Define a branch of f(z) which is analytic in the interior of the unit disk |z| < 12. The attempt at a solution
Who is forcing you to take the branch cut along the real segment [-1,1]? If you do that you cannot make your f(z) analytic in the unit disk about z = 0, at least not easily.
No one is forcing me to, I suppose I could alternatively take branch cuts from -1 to -infinity and from 1 to infinity. I'm still having difficulty making the next step, does my choice of branch cut like this mean I have analyticity everywhere but on the cuts or have I misunderstood them?
Yes, use the branch cut (-infinity,-1] for ##(z+1)^{1/2}## and [1,infinity) for ##(z-1)^{1/2}##. The function of the branch cuts is to make sure every path that circles a branch point will cross a branch cut.
So if I take my branch point at z=-1 and express ##(z+1)^{1/2}## in polar form I would let it's argument vary from (-pi, pi] so it starts and ends at the branch cut then do a similar thing around the other branch point except varying [0, 2pi)?
That sounds roughly correct. Except the intervals aren't going to include the end points pi and 0, right?
Ok because then it would be crossing the branch cut? So if I express each of the parts as mentioned there that will give me an analytic branch on the interior of the unit disk?
Well, yes. The only places the product of the functions won't be analytic is along the branch cuts. None of those places are in the interior of the unit disk, are they?
No so the branch is analytic there, thanks. The next part of the question asks for analyticity on the exterior of the disk with the hint ##z^{2} - 1 = z^{2}(1-z^{-2})##. I assume I approach this in a similar way except a branch cut from 1 to -1 now makes more sense?
Sounds like a good strategy.
Ok thanks for all help and clarification
Could you (or someone) explain why the intervals for the branch cuts don't include the endpoints? A branch cut for ##(z+1)^{1/2}## is the line extending from -1 to infinity. So ##(z+1)^{1/2}## is discontinuous across this line. I thought by leaving one of the endpoints open, it would not be a problem since we guarantee discontinuity.
Also, why is that these two branch cuts necessarily allow for analyticity in the interior of the unit disk?
Thanks.
  • · Replies 26 ·
