Composition of Vector Functions in Mathematica
The discussion focuses on defining and composing vector functions in Mathematica, specifically using matrix operations. The user aims to create functions A and B that can be composed efficiently, encountering issues with output formats. The solution involves defining matrices A and B as nested lists and using a dot product for composition, allowing for the inclusion of translation vectors. The final syntax provided for composition is Composition[A,B,A][{x,y}], which successfully evaluates the desired function.
  • Understanding of matrix operations in Mathematica
  • Familiarity with vector representation as lists
  • Knowledge of function composition in programming
  • Basic syntax of Mathematica for defining functions
  • Research "Mathematica matrix operations" for advanced techniques
  • Learn about "Mathematica function composition" for more complex scenarios
  • Explore "Mathematica list manipulation" to handle different data structures
  • Investigate "Mathematica graphics" for visualizing vector transformations
Mathematica users, mathematicians, and programmers interested in linear algebra applications and function composition techniques.
Identity
I want to define something like:
A\left(\begin{matrix} x \\ y\end{matrix}\right) = \left(\begin{matrix} 1 & -1 \\ -1 & 1 \end{matrix}\right)\left(\begin{matrix} x \\ y\end{matrix}\right)
B\left(\begin{matrix} x \\ y\end{matrix}\right) = \left(\begin{matrix} 0 & 1 \\ 2 & -1 \end{matrix}\right)\left(\begin{matrix} x \\ y\end{matrix}\right)+\left(\begin{matrix} 1 \\ 1\end{matrix}\right)
And then I want to be able to evaluate compositions such as A \circ B \circ A\left(\begin{matrix} x \\ y\end{matrix}\right) quickly and easily.
Currently I'm using this syntax:
A[x_,y_] = {{1,-1},{-1,1}}.{{x},{y}}
However, when I define such a function, the output is a column vector, not a list, and I can't input a column vector into the next function. How do I do ths?
If I understand your syntax correctly, you have too many brackets in the column vector definition. A column vector should be just a simple list, and a matrix should be a nested list. Instead of:
Just define:
A = {{1,-1},{-1,1}}
B = {{0,1},{2,-1}}
X = {x,y}
Then you can simply compose them with the dot product, such as:
(A.(B.A)).X
I can't do that, because B has a translation vector
Is this what you are looking for?
In[1]:= A[{x_,y_}]:={{1,-1},{-1,1}}.{x,y};
B[{x_,y_}]:={{0,1},{2,-1}}.{x,y}+{1,1};
Out[3]= {-2 x-2 (x-y)+2 y,2 x+2 (x-y)-2 y}
I'll have to try it out when i get back tonight, but that looks very promising, thanks :)
  • · Replies 33 ·
