Computer plot of particle orbits around Kerr black holes
The discussion revolves around computing and plotting the orbits of particles around Kerr black holes, utilizing equations derived from the Kerr metric. Participants are exploring the implementation of these calculations in MATLAB and comparing methods from different editions of relevant texts, specifically focusing on the effective potential and integration techniques.
  • One participant describes their project involving Kerr black holes and the equations they are using from Hartle's book, specifically equations related to the Kerr metric in the equatorial plane.
  • Another participant suggests that the GROrbits code may have changed from earlier versions and discusses the challenges of understanding the code.
  • A participant notes that the parameter values for angular momentum, energy, and spin can sometimes yield unphysical results, indicating the need for careful selection of these parameters.
  • One participant mentions that they believe the method for computing orbits remains consistent between the first and second editions of Taylor's book, despite some differences in the equations presented.
  • Another participant expresses confusion over the simplification of symbols in the equations and has developed their own equations based on generic metric coefficients.
  • There is a clarification that the main difference between the two editions of Taylor's book is the generalization of the equations for all values of the spin parameter a, rather than just the maximal Kerr black hole case.
Participants express differing views on the changes in the GROrbits code and the interpretation of equations between different editions of the texts. Some agree on the consistency of the methods used, while others highlight the complexity and potential confusion in the equations.
There are unresolved aspects regarding the parameter values used in the calculations, as well as the specific implementation details in the GROrbits code that may affect the outcomes of the orbit computations.
This discussion may be useful for individuals interested in computational physics, particularly those working on simulations involving black hole physics and particle dynamics in strong gravitational fields.
Dick Taid
Hi there,
First post, so be gentle. I'm currently doing a project on Kerr black holes, part of which is based on a project in Edwin F. Taylor's book "Exploring Black Holes" (the chapter is found here) as well as some of Hartle's book (chapter 15). Part of my project, and as a way of better understanding some principles, as well as getting up to speed with MATLAB again, is making a little program that can compute and plot the orbits of particles.
Basically I'm using the terms from Hartle (eqs. (15.18b) and (15.19) (I won't bother with my derivations of them here) derived from the Kerr metric in the equatorial plane:
[tex] d\tau^2 = \left(1 - \frac{2M}{r}\right) dt^2<br /> + \frac{4Ma}{r} dt d\phi<br /> - \frac{r^2}{\Delta} dr^2<br /> - R_a^2 d\phi^2,[/tex]
where [itex]a[/itex] is the spin parameter, [itex]R_a^2 = r^2 + a^2 + \frac{2Ma^2}{r}[/itex] is the reduced circumference, and [itex]\Delta \equiv r^2 - 2Mr + a^2[/itex]. Calculations give (15.18b): [tex] \frac{d\phi}{d\tau} = \frac{1}{\Delta}\left[\left(1 - \frac{2M}{r}\right)\ell + \frac{2Ma}{r}e\right][/tex]
and (15.19): [tex] \frac{e^2 - 1}{2} = \frac{1}{2}\left(\frac{dr}{d\tau}\right)^2 + V_\text{eff}(r,e,\ell)[/tex]
where
[tex] V_\text{eff}(r,e,\ell) = -\frac{2M}{r} + \frac{\ell^2 - a^2(e^2 - 1)}{r^2} - \frac{2M(\ell - a\cdot e)^2}{r^3}.[/tex]
Now, following Hartle's example (I think it's in Taylor as well), one finds the orbit of a particle, moving radially inwards, by [itex](dr/d\tau)/(d\phi/d\tau)[/itex], which is somewhat simple enough. I haven't written an expression for it, as it isn't very pretty, but by solving that differential equation, I get a nice plot of what I wanted. That is
http://dicktaid.com/kerrorbit.jpg
(here [itex]a=M[/itex], [itex]e = 1[/itex] and [itex]\ell = 0[/itex]). The same can be achieved by using the program Taylor supplies on his webpage (the GRorbits.jar file) which he uses in his drafts of the second edition of his book (http://www.eftaylor.com/exploringblackholes/SpinBH111107v2.pdf). I want to be able to plot bound orbits as depicted in fig. 16.9-10. Inserting those values in my MATLAB code gives an error (the values he uses for angular momentum, energy and spin parameter implies [itex](dr/d\tau)^2[/itex] is negative).
I'm trying to understand the coding done in the GRorbits.jar file, that is, I'm trying to understand how those orbits are achieved. I've looked around in the books, as well as the net, to find something that helps me make sense of it. Perhaps I'm searching for the wrong things, but I'm not able to locate what I'm looking for. Any pointers you guys can give me is appreciated.
EDIT: Fig. 16.9 from Taylor's drafts so you don't have to download it:
http://dicktaid.com/boundorbit.jpg
Beginner here, but I think I have been there or thereabouts recently ;)
I might be wrong, but I think GROrbits no longer uses those equations. I looked at the code myself, and I believe it now uses code developed along with the second edition of that book, the text of which is open for review at the book's site.
That said, the existing code is still pretty difficult to reverse-engineer (well I couldn't fathom it, and I thought I knew what to look for!), so you might be most successful if you develop your code "alongside" the two methods already there using your working algorithm, making use of the vast quantities of GUI code provided.
As for your parameter issues, sometimes the a, E and L values really are unphysical. That's when I use GROrbits to check if there really is a solution.
Thank you for your suggestions. I've just looked at the source code of GROrbits, and I think I've suffered a massive brain aneurysm -- JAVA apparently makes less sense than I remembered.
Looking at Taylor's draft again, it doesn't appear they have used another way of computing the orbits, than they did in the first edition. As it says on page 21
To obtain the full spatial orbit, we must integrate (16.44) for [itex]r^*(\tau^*)[/itex] and simultaneously integrate (16.39) for [itex]\phi(\tau^*)[/itex]...
which is pretty much what I'm doing.
Sure, just checked page & equation nos. It's the same method (effective potential), just with different equations (well, they look very different to me!).
I ended up doing my own equations based on generic metric coefficients because I didn't like the way they reduce the symbol m to the value "2". That's just confusing IMO.
The only difference between the two editions, equation-wise, is that they in first edition confine themselves to the maximal Kerr black hole ([itex]a=M[/itex]), while in the second edtion they generalize for all values of [itex]a[/itex], as well as converting to unitless entries by dividing through with [itex]M[/itex]. But other than that, it's the same. :)
Anyone else?
  • · Replies 43 ·
  • · Replies 16 ·
