Computing isoclines for a dynamical system
4 replies · 2K views · last reply
Master1022
Compute the isocline of the following system.
N/A
Hi,
I was doing some practice problems online for dynamical systems and came across the following question about isoclines. It left me with 2 questions that I hoping to get some insight to.
Question:
1.
What are isoclines? (I have tried doing an internet search, but the results don't help me)
2. How can we calculate the isoclines?
Example:
Imagine we have the following dynamical system:
[tex]\dot x_1 =x_2 - x_2 ^3[/tex]
[tex]\dot x_2 = -x_1 - x_2 ^2[/tex]
Compute the isoclines of the system.
Attempt:
The solution simply does:
[tex]\frac{d x_2}{d x_1} = \frac{\dot x_2}{\dot x_1} = \frac{-x_1 - x_2 ^2}{x_2 - x_2 ^3}[/tex]
and then evaluates different cases based on values. However, I don't quite understand why we are doing this method.
Any help would be greatly appreciated.
An isocline is defined to be the set of points on the ##(x_1,x_2)## graph where the solution curves have a fixed slope. For example, find all the points such that the solution going through that point has a slope of 2.
The slope in general is ## d x_2 / dx_1## which is why they computed that value.
Thanks @Office_Shredder ! That makes sense. Just to check my understanding, does that mean that if we wanted to, for example find all the points that have a slope of ## k## then we would solve the equation below?
[tex]k = \frac{-x_1 - x_2 ^2}{x_2 - x_2 ^3}[/tex]
This would result in the curve/etc. of those points
That's right. The idea of these is if you draw some of them for different ks, then when you try to draw a solution curve, you know what the approximate slope is in each section of the plane.
Many thanks! Really appreciate the help. Will have a think about it and have another go at the question
