Comsol: Infinite Element Domain module
8 replies · 5K views · last reply
madani
Hello folks,
I want to simulate a 2D heat transfer process in the subsurface on a region which is infinite on the r-direction. So, as you know, the very basic way to model this is to draw a geometry that is very long in the r direction. I have done this, and the results that I obtain is correct as in this case, the results are matched with the analytical solution. As you know, there is a capability in Comsol called infinite element domain which serves the purpose to the problem mentioned above. In this case, we need to define a limited geometry on which we want to solve the PDE, and also need to draw a small domain acting as the Infinite Element Domain. However, in this case, the results are not correct because they are not matched with the analytical solution. Is there anything that I am missing to correctly use Infinite Element Domain in Comsol?
Any help or comment would be appreciated.
There are some examples of analyses involving infinite elements in Comsol's Application Gallery. Have you checked them ?
Hi, thanks for your reply.
Yup, I have checked them, and I think I am doing it right for the problem that I am considering. I have a question; to numerically solve an infinite region problem, one way is to draw a very lengthy region, right? And, now one functionality of infinite elements domain feature of Comsol is to replace this infinite region with a finite region and then stick to it an infinite element domain, right?
Yes, with sufficiently large models it’s usually possible to approximate unbounded (or almost unbounded when compared with the ROI) domains. But infinite elements allow you to reduce the computational effort by performing the analyses on much smaller geometries. Those elements are often used in acoustics and even solid mechanics (e.g. infinite plates).
Can you attach some pictures showing your model ? It would be easier to give some advice.
Thanks again for your prompt reply.
Please consider this geometry
Schematic of a radial domain on a Z and R axis: an orange band with arrows labeled Conduction + convection direction, Constant Temp Inner BC at the left end, and Constant Temp at infinity at the right end.
At the inner BC, a fluid at constant temp is injected, and far at the infinity, the boundary condition is another constant temperature (lower than that at the inner BC). Also, the temp at initial condition is the same as that at the outer boundary condition. Now, the general way to model this is to draw this geometry whose length in the r direction is large. The simulation results are correct until the temperature at the outer boundary condition starts to increase. The problem has an analytical solution, based on which I have verified the numerical results.
Another way to model this, is to use infinite element domain in Comsol. For this, the above geometry can be replaced with:
Schematic of a radial domain: an orange bounded region labelled Conduction + convection direction with arrows pointing right, followed by a blue infinite element domain. Labels: Constant Temp Inner BC, Constant Temp at infinity.
In this case, I assume even if temp at the outer boundary (at the bounded region, not at the infinite element domain) starts to increase, the results should be correct. However, the results in this case, is incorrect (unverified against the analytical solution). I wonder what I am missing, or if I am doing something wrong in Comsol?
Thanks again.
What are the differences in the results (analytical, finite element only model and the one with infinite elements) ?
Here are the results that I get:
Scatter plot of Temp against r in metres from 0 to 140 with three series: a blue series falling to about 29 at r = 140, an orange series and a grey analytical curve that both fall to about 56.
Either I am missing something on how I should implement this Infinite Element in Comsol, or I am mistaken to believe that Infinite element works for this scenario.
Let me elaborate more on the problem:
A fluid with high temperature is being injected into a region with lower temperature:
Schematic of a 1D radial domain with R on the horizontal axis and Z on the vertical axis; a long orange bar with arrows labelled Conduction + convection direction, Constant Temp Inner BC at the left end and Constant Temp at infinity at the right end.
The equation to solve is:
Radial heat equation: C[dT/dt + v dT/dr] - lambda[d2T/dr2 + (1/r) dT/dr] = 0, with v = q / (2 pi r phi h), where the constants are as written in the image.
With the following initial and boundary conditions (note that the upper and lower boundary condition is no-flux):
Text showing initial temp T = 20 degrees centigrade, and boundary condition T at rw (inlet BC) = 70 degrees C and T at (r→infinity) is 20 degrees centigrade.
We want to obtain the temperature profile over the length of rw<r<140 m (rw is very small and is equal to 0.005 m here) at different times. One way to model this numerically in Comsol is to draw a rectangle that is 2000 m in the r-direction, and get results only in the span of r [rw,140] m:
COMSOL Graphics window showing a long thin grey horizontal rectangle on a grid, spanning roughly 0 to 1960 m in r, with a red dash-dot line marking r=0 on the left axis.
The results of this case is fine, because they are well-matched with the analytical solution.Another way to model this is to replace the above geometry with a bounded one that is [rw, 140] m in the r-direction and then augment it with an Infinite Element domain that is meshed mapped, as follows:
COMSOL Graphics window showing a 2D axisymmetric mesh: a long dense triangular mesh strip from r=0 to about r=140 m, outlined in red, with a small rectangular mesh region at the right end near r=140-148 m, and an r=0 axis line on the left.
Here, I have set the thickness of Infinite Element to 10 m in the r-direction. However, the results in this case are not matched with the analytical solution (or the above case where Infinite Element domain was not used). Is there anything that I am missing in Comsol? I have also changed some variables with regard to Infinite Element in Comsol such as physical width or distance, but I didn't see any changes in the results.
Thanks for your assistance.
Do the temperature and heat flux contour plots look correct in the case when infinite elements are used ? Are their distributions continuous at the interface of these two domains ?
The temperature profile:
Line graph of dependent variable Tm (degC) against r-coordinate (m) from 0 to 150, showing temperature falling from about 70 degC near r=0 to about 20 degC at r=150, steepest beyond r=100.
The temperature gradient (representing heat flux) profile:
Line graph of the r component of the gradient of Tm in K/m against r-coordinate in m from 0 to 150, a curve falling from 0 to about -0.99 K/m, legend 1E5 d.
The bounded region or the so-called ROI is 0.005<r<140 m and physical width of infinite element in the r-direction is 10 m. As you can see, the temperature and its gradient are both continuous at the interface (r=140 m).
As far as temperature and flux contours in both the bounded region and infinite element are concerned, I don't see anything suspicious. Here, for example, the contour map of temperature is:
COMSOL contour plot of Tm in degC at time 1E5 d, a rectangular domain from x = 0 to about 150 m and y from 0 to 20 m, with vertical contour lines shifting from red near x = 40 m through yellow and green to blue and dark blue near x = 150 m; colour legend from 21.25 to 68.75 degC.
